383 stroker
Old Aug 12, 2009 | 05:36 PM
xemilliox's Avatar
xemilliox
Default 383 stroker
I want to stroke my 78 vette to a 383 but dont know much about it. Does anyone know a good place to buy a cheap kit and also would I need to upgrade my cam or heads or anything else? Thanks
Old Aug 12, 2009 | 05:44 PM
Phil Zell's Avatar
Phil Zell
If your profile was completed someone in your area could possibly help you
Old Aug 12, 2009 | 06:13 PM
Gordonm's Avatar
Gordonm
A couple of things, if you go cheap you get what you pay for. Yes a good set of heads will help and a better cam will help. make sure you match all your components. Building an engine is not just throwing parts at it. You might be better off buying a crate engine.
Old Aug 12, 2009 | 06:55 PM
schmegeggie's Avatar
schmegeggie
When you say you "don't know much about it". Does that mean you don't know much about engines, or stroking a 383?
Either answer, get someone who does, or go crate.
Old Aug 12, 2009 | 07:31 PM
xemilliox's Avatar
xemilliox
I know enough about engines to rebuild one and I understand the "stroking" concept I guess what my real question is what to do about my camshaft? I beleive my heads are 175 on there now and that should sufice but as far as matching up a good cam I am lost.
Old Aug 12, 2009 | 07:37 PM
Gordonm's Avatar
Gordonm
175?? what are the heads. If that is the size of the runner they are tiny. Not enough for a 383. I run 190s on mine and it is small for my 385 motor. Good enough for 409 RWHP but I have a large solid flat tappet cam. What are your HP levels you want out of the engine. Is it a street car a daily driver weeknd cruiser or drag race car. All this will come into play when selecting the engine components.
Cams are a whole project in itself. Do you want a flat tappet or roller $$$ cam.
Old Aug 12, 2009 | 09:58 PM
xemilliox's Avatar
xemilliox
the car is a weekend driver and I am hoping to get around 450 HP. As of right now the only engine upgrades are an edelbrock performer series intake and carb, and all the emissions has been taken off and I am now using hooker headers.
Old Aug 12, 2009 | 11:19 PM
billla's Avatar
billla
St. Jude Donor '14
There are a ton of questions here
Why have you decided on a 383?
Do you have any concerns about maintaining the originality of your engine?
What's your budget? <- this is really the key question
Old Aug 13, 2009 | 07:51 AM
schmegeggie
In that case, go with a kit. I had two pros pick all my parts seperately(both have 70 years combined engine building experience). Heads, Comp cam, pistons, crank, etc. I'm around 425HP with as much cam as we could get. Open glasspack side exhaust, and removal of the clutch fan, now dual electrics, helped to add a few HP too. Great street motor! I really like the results. These guys knew what they were doing and really got into it! Like a couple of West Virginians poking a rat with a stick in the bottom of a trash can while drinking beer! (no offense to anyone, just the best analogy I could think of)
Old Aug 13, 2009 | 08:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
Might be best for you to buy a proven longblock thats done.
These days its cheaper to go that route in most cases (coming from a chronic DIY'er)
Too many "rebuilders" will spout off "You should have XX" when done only to find out otherwise after the thing is installed.
Check out Pace Performance, its a start.
To 383 stroker
