Bleeding brakes with vacuum pump
You need to use a rather large jar with a good seal to catch all the brake fluid.
No hand pumping involved, and there are no mods to the MC cover. You just have to keeping adding fluid to te MC.
I do regularly use a hand pump to one-man bleed my brakes in my other cars. The scenario described above was for a special project whereby I was completley replacing the whole brake system in the vette.
Here's how my foray in to bleeding the brakes went:
Preface: I've bled brakes and clutches on cars and bikes of all sorts, foreign and domestic. The operating principle of the Proportioning Switch makes the Corvette brake bleeding an interesting experience.
Got my little hoses and my slick vacuum pump, I read all the sticky stuff here about bleeding the brakes, and I'm feeling pretty clever.
2 hours later, after watch more bubbles than a school of flatulent fish, I'm not feeling so clever anymore.
Return to thread. Read about the shop vac. Walk out to shop feeling clever again.
1 hour later, come in to take Tylenol (the doc says I can't motrin anymore), console myself with a cold one and consult the thread again.
Read about gravity bleeding. I believe in gravity, so I decide to give it a whirl.....
welp, apparently my car does NOT believe in gravity.
A couple more consolation beverages, a cheeseburger, couple more tylenols, and I'm starting to think very creatively. I feel like genius by now (not).
Eventually, I put about 30" of clear tubing on the front right and rear left bleed screws, placed the ends in jars placed above on the fenders (on fender mats of course).
Now I pumped the pedal slowly until fluid started to fill the tubing. stopped here and ensured the m/c was topped off.
back to the pedal, I pushed it to the floor sloooowly and held it there while the bubbles traveled to the top and the fluid settled at the bottom. let the pedal out slowly and repeated this 3 more times.
Changed sides and did the process again.
Note:
Having a cold one nearby really helps make waiting for the bubbles seem like less of a wait.
So That was all that was needed to fill and purge a dry system. The brakes are very firm and the car stops straight. Since this is a resto, I will wait a couple of days and re-bleed, because I know there has to be some air in there still and I want to spend a little more time on the inside rear bleeders.
Note:
my setup is like the hand system you first showed.
except I used a hard plastic 1/2gallon clear juice jug.
used a 5 foot piece of compressed air hose in the cap and other end
run up the vacuums hose.
long piece of clear tubing run through the cap to bottom of jug
and connected to bleeder.
the trick is opening the bleeder, looking for clean clear fluid, and the
careful closing of bleeder. air will leak past the bleeder threads and
give false info about where it is coming from.
I feel bad about your experience.
