Frame mounts
Old Aug 13, 2009 | 02:34 PM
bspit4's Avatar
bspit4
2nd Gear
Default Frame mounts
Hi all,
I am currently working on a 77 and have removed the body from the frame.
The #1 and #4 frame mounts are rusted and the hole that the rubber mounts fit in are larger than they should be. I would like to repair the mounts insted of replacing them.
Can anyone tell me the diameter of the hole that the rubber mounts fit in?
Old Aug 13, 2009 | 05:26 PM
MIKE80's Avatar
MIKE80
I had the same problem on my 80. I made inserts that I welded in. I don't remember the size holesaw I used, so I just took a measurement; it has been powdercoated and it measures 1 1/8" diameter. I am using poly bushings and they fit snug.
http://forums.corvetteforum.com/c3-t...-brackets.html
Old Aug 13, 2009 | 06:24 PM
Scott Marzahl's Avatar
Scott Marzahl
I did basically the same thing, I ended up using a 1.25" hole saw.
http://blog.scottsvettetalk.com/2007...nt-repair.aspx
Old Aug 13, 2009 | 10:46 PM
bspit4's Avatar
bspit4
2nd Gear
Thanks for the replies. That helps a lot.
To Frame mounts
