79 Drivers door handle linkage not connected.
Old Aug 13, 2009 | 07:44 PM
jotto's Avatar
jotto
Default 79 Drivers door handle linkage not connected.
On my new Vette, I cannot open the drivers door using the outer door handle and the key wont turn in the lock. I removed the inner door panel and noticed that the rod hanging from the handle wasnt connected to anything.
The handle was not secured in place and I lifted it out and the rod fell off.
Can any one post up a diagram or exploded view of how this rod connects to the handle and where it connects to the door lock mechanism please.
Thanks.
Old Aug 14, 2009 | 01:42 PM
jotto's Avatar
jotto
Any one got an AIM handy they could check out for me? Mine appears to be somewhere mid ocean! lol
Old Aug 14, 2009 | 08:18 PM
Duke94's Avatar
Duke94
Here's a couple of pics. I have the AIM too if this doesn't do it for you.
Gary
Old Aug 14, 2009 | 08:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Your outside door handle is missing the lever pull back spring too!
Willcox
Old Aug 15, 2009 | 06:25 AM
jotto's Avatar
jotto
Willcox
That would be the one shown in the pic above, ie
Will see if I have anything similar! Is it possible to use the items from the pasenger side or will they be back to front! lol
Old Aug 15, 2009 | 06:48 AM
Ganey's Avatar
Ganey
Worth a check in the bottom of the door for parts. The pass. side clips should work. As you are in the U.K., clips are commonly used to hold the L end of the rods in many cars (normally plastic clips are used which will work).
Old Aug 15, 2009 | 10:08 AM
jotto's Avatar
jotto
Looks like I need the spring as well...nothing in the base of the door
Are these springs avilable as an aftermarket part or would I need a complete door handle assembly?
Old Aug 15, 2009 | 10:23 AM
john roth's Avatar
john roth
When I put mine new ones in the locks would not unlock. After hours of adjusting and messing around I found the problem was elliminated by adjusting the rod you found disconnected. Threading the connector up and down to the correct location is necessary. In my situation I noticed that when connected if I set it pretty much in the center of the "slack" area and everything worked great. Just a little experience sharing.
JR
Old Aug 15, 2009 | 12:00 PM
0Willcox Corvette
Former Vendor
To my knowledge the spring is only available with the handle.
Willcox
Old Aug 15, 2009 | 03:59 PM
jotto's Avatar
jotto
Willcox, How much can you do an aftermarket handle for shipped to the UK with a gasket? Not worried how long it takes so USPS would be fine if you ship using them. Also, as this is a temp fix, not worried about it being an import....sorry guys! Just want to get in and out of the car whilst I work on her!
To 79 Drivers door handle linkage not connected.
