Which rear spring?????
Old Aug 16, 2009 | 05:19 PM
zigvs's Avatar
zigvs
I was told composite springs are prone to damage from road debris.Is this true?
Old Aug 16, 2009 | 05:31 PM
jb78L-82's Avatar
jb78L-82
I would guess that hitting something really big underneath a C3 with a composite spring would make the composite more prone to damage than steel but I have had mine on my car since 1987 with zero issues. I really try to avoid those big items in the road when driving my 78!
Old Aug 16, 2009 | 06:03 PM
zigvs's Avatar
zigvs
I was told rocks kick up and can nick the spring and ruin it
Old Aug 16, 2009 | 08:54 PM
78aldo's Avatar
78aldo
Looks like the 9 leaf wins this debate.Not willing to change out front and rear suspenion for the F-41.Sure like knowing how,tho.Wife and I not going road racing anytime soon but car will be down a dragstrip a time or two.Thanks you guys for the great input.
Old Aug 17, 2009 | 02:17 AM
RunningMan373's Avatar
RunningMan373
You'll change to a 7 leaf, soon after. A stiffer rear spring holds the car in fast highway maneuvers, not allowing it to wallow, etc. cadilacs are also "balanced". Is your spring a 2.25 or a 2.5"? it will affect the rate of the spring you get. The 2.25 are 196lb/in. where the 2.5's are 260. many, many members (vast majority, really) upgrade the rate of their rear spring w/o changing the fronts. I've yet to hear one complaint of the loss of balance. meter at 7.5 and rising.
Old Aug 17, 2009 | 04:51 PM
78aldo's Avatar
78aldo
Ok,Advice taken. Just got off the phone.Ordered the SEVEN leaf spring.I'm sure that is the best way to go,as I'll be able to upgrade the rest further down the road.Now I can't wait for it to get here,so I can get at it.
Old Aug 17, 2009 | 09:47 PM
RunningMan373
Your gonna love the 7 leaf! I noticed the improvement immediately. you'll also need new spring bushings, getting those also? Go with a good supplier on those, there's some forgien made junk out there that looks great new, but will crack pretty bad with in a few months. Paul 74 http://forums.corvetteforum.com/c3-t...-cushions.html has a good source on these for the rubber ones. For very stiff poly's Van Steel has the best. http://www.vansteel.com/ call for the part, they don't list it. btw, did you measure the rear spring width?
Van steel poly's on my '73
Paul 74's rubber replacement rear bushings:
Old Aug 18, 2009 | 05:23 PM
78aldo's Avatar
78aldo
I replaced the bushings and bolts earlier this year as the old stuff was in pretty rough shape.I bought 6" bolts and poly bushings .Good coice?
Old Aug 18, 2009 | 05:32 PM
RunningMan373
That's what i'm running. Should give you good 'ballance'
Old Nov 26, 2012 | 11:26 AM
AfterMidnight's Avatar
AfterMidnight
1st Gear
Can you provide the website and part number? I have a 78 and would like to purchase the 7 leaf. I need to raise it about two inches. Any ideas?
