Advice on header selection
Old Aug 14, 2009 | 10:19 PM
imariver's Avatar
imariver
Default Advice on header selection
Thinking about putting headers on my 73 L48, strickly for street and show. Anyone have any advice on selection?
Thanks, Steve
Old Aug 14, 2009 | 10:36 PM
dstaley's Avatar
dstaley
I have the cheap summit ones. The fit is outstanding, the welds look just fine and the flanges, well, they're as good as almost anyone else's. Other than replacing the collector flanges with much thicker ones, I'm very happy with mine. Hooker are probably better but often need some "adjustments" to clear everything.
The finish doesn't last long at all, so if you're thinking of a coated set I don't have any wisdom to offer. I wish these were stilll offered with ceramic coating as an option.
Old Aug 14, 2009 | 10:57 PM
Roughrider's Avatar
Roughrider
No matter what brand you decide to go with...get ceramic coated or the quick rusting will defeat your purpose of the "show" part of street and show.
Old Aug 14, 2009 | 11:01 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I recommend the dynomax cerama-coats. Equal length long tubes. I installed these on my 73 two years back and never looked back. ~3k miles and a cam break in they still look new!
Here is a good view of the right side.
Old Aug 14, 2009 | 11:16 PM
Grumpy 427's Avatar
Grumpy 427
How do the dyno max fit with the auto transmission shift linkage? I have Headman, and they run into the linkage. I need a new set .
Old Aug 15, 2009 | 12:02 AM
MN80Vette's Avatar
MN80Vette
I've had Dynomax ceramic coated full length for a few years. Excellent fit (although I can't speak for the AT part). They still look great and perform even better.
Old Aug 15, 2009 | 07:56 AM
1979super_vette's Avatar
1979super_vette
I have a set of hooker super comp (tuned port) ceramic coated headers and i love them. They fit perfect and honestly how often can u tell the wife you were in the garage messin with a couple hookers and her not get mad????????
Old Aug 15, 2009 | 08:02 AM
jb78L-82's Avatar
jb78L-82
That is very funny and a great point! If you want to keep a stock type exhaust hook up, don't mind the extra cost, and will fit EXACTLY like the stock exhaust manifolds, you may want to consider McJacks Shorty headers (not block huggers) like I use. They are expensive, though!
Old Aug 15, 2009 | 08:49 AM
Ganey's Avatar
Ganey
The Dynomax Corvette SB Cerama-Coat headers fit & flow great. I have been rec. them & many have them now.
Both SB Hooker Super Comps & Dynomax Cerama-Coat Headers are excellent for performance.
Old Aug 15, 2009 | 09:40 AM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
I've got Patriot ceramic block huggers. They fit my '74 sb great and still look good after 2 yrs.
Old Aug 15, 2009 | 05:13 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by dstaley
Hooker often need some "adjustments" to clear everything.
Not true.
Old Aug 15, 2009 | 06:47 PM
imariver's Avatar
imariver
Do any or all of these header flanges match the port configuration of the heads?
To Advice on header selection
