Its hot!need a/c
Old Aug 15, 2009 | 10:59 PM
corvette138's Avatar
corvette138
4th Gear
Default Its hot!need a/c
1979 corvette replaced a/c lines. pump, converted t0 134 gas.put in new relay last yr. blower works no cold air, any suggestions? clutches dont seem to be working pump is less than two years old and worked fine before. Need help, its hot, corvettes of carlise just around the corner need air for the trip. SUGGESTIONS APPRECIATED THANKS!!!! tried putting in more freon guage resd full still wont engage clutch any other suggestions??
Old Aug 15, 2009 | 11:32 PM
MIKE80's Avatar
MIKE80
If you don't run the a/c compressor once in a while during the year and get some oil to the seals, there's a good chance that the gas leaked out due to dry seals which would cause the a/c clutch not to engauge. It may just need to be recharged.
Old Aug 16, 2009 | 08:45 AM
08vycpe's Avatar
08vycpe
Use a jumper wire on the pressure switch in the high side line near the compressor to see if the compressor will run.
If the refrigerant is too low in the system this switch will prevent the compressor from running.
I assume you pulled a good vacuum for 1/2 hr to 1 hr and checked to see if it would hold before you put in the refrigerant.
Old Aug 16, 2009 | 09:02 AM
Ganey's Avatar
Ganey
As both said, it's probably low on freon.
This is most likely why it doesn't turn on. The pressure can be checked w/ system off.
I am running R-12 & the expected pressure would be around 100 psi off.
W/ key & A/C on, power to the compressor can be checked.
Old Aug 16, 2009 | 09:10 AM
c3_dk's Avatar
c3_dk
Move to Denmark, here it is cold all year !!! :-)
To Its hot!need a/c
