Seattle area Muncie rebuilder?
Old Aug 16, 2009 | 07:21 PM
66L36Coupe's Avatar
66L36Coupe
Default Seattle area Muncie rebuilder?
I'm going to have the M22 in my '70 freshened-up. Can anyone recommend a shop who does excellent mechanical and NCRS-level cosmetic work?
Trans works fine, but the whine is EXTRA loud leading me to believe it's not correctly set-up, also has a slow fluid leak from the main case / tail housing seam...
Thanks!
Old Aug 16, 2009 | 09:10 PM
Frogday's Avatar
Frogday
Thanks!
Try calling Corvettes of Auburn and ask for Dan. If he doesn't do it, he will know who to contact. He does NCRS-type restorations.
Old Aug 16, 2009 | 11:24 PM
Solid LT1's Avatar
Solid LT1
Since you have a ZR-1 you should talk with Dave Herlinger at Corvette Repair (corvetterepair.org) as he is a EXPERT on M-22 Muncie transmissions. I know freight might be a little expensive to California but his work is second to none.
Old Aug 16, 2009 | 11:56 PM
66L36Coupe's Avatar
66L36Coupe
Interesting idea. I used a Monaco Orange '69 as partial trade for the ZR1. The car was an L46 from Cupertino CA by way of Mann Chevy in LA. The previous owner had Dave do all the work on the car - had thousand$ in receipts from his shop. Worth a call.
I'll try calling the local guy and also ping Dave. Thanks for the advice, guys!
To Seattle area Muncie rebuilder?
