broken door latch
Old Aug 16, 2009 | 09:50 PM
wjr152's Avatar
wjr152
Default broken door latch
playing with my dad's 1968 today and tried to close the passenger door and it didn't want to close. finally i got it and now... it wont open. looked down the panel and saw a broken latch inside. theleft of the two metal pieces has broken & stuck down. any suggestions would be VERY helpful. also, if you know a safe way to remove the door panel with the door fixed close that would also be apreciated. thanks for your help guys!!!
Old Aug 16, 2009 | 10:09 PM
SmokinBBC's Avatar
SmokinBBC
Hard to tell what is broken by your description.
You should be able to use a jimmy to pull up on the latch release mechanism. I used a seal puller to pull up on the latch.
http://www.jcwhitney.com/webapp/wcs/...&redir=k216837
Old Aug 16, 2009 | 10:21 PM
mapman's Avatar
mapman
A suggestion if you can't tell what part of the latch mechanism you need to trip:
Look down into the DRIVER'S side door panel as you operate the interior or exterior release mechanism to see how the door lock moves. You might want to remove the driver's side door panel to get a better look at how the lock mechanism works.
I would expect significant damage if the door panel is removed with the door closed.
Old Aug 17, 2009 | 07:59 AM
DZRick's Avatar
DZRick
My passenger side panel is off right now and I'll see if I can get some pictures to show you how to get yours open.
Old Aug 17, 2009 | 08:34 AM
wjr152's Avatar
wjr152
It is hard to describe but there are two betal latches inside the door panel and the left side one is stuck down. its odd how this break causes the door to lock shut but seems like the situation. might be getting in & out "dukes of hazard" style for a bit i guess
Old Aug 17, 2009 | 08:54 AM
DZRick's Avatar
DZRick
wjr152,
Please edit your last post and delete that spammers link.
I'll get to work getting those pictures for you asap.
Old Aug 17, 2009 | 09:26 AM
wjr152's Avatar
wjr152
i dont go on here much &wasnt sure what thatwas. thank you
To broken door latch
