Head Gasket Problems??
Old Aug 17, 2009 | 02:46 PM
sstopczy's Avatar
sstopczy
Default Head Gasket Problems??
I changed my oil a week ago and the nylon gasket on the oil plug cracked so I changed it a few days later after I put the new oil in. When I switched that gasket out the little bit of oil that came out before I could get my finger over the hole appeared to have some antifreeze in it. I know the overflow tank always empties somewhere because I can put some coolant in and in a few days it is gone. I think it is the head gaskets but would like to hear what others say before I go too far.
Thanks!
Old Aug 17, 2009 | 03:01 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Could be a headgasket, or the corners of the intake manifold gasket. Do you have an aluminum intake? They are more prone to leaking. You can get a "block tester" from your local Napa store. Use it to check for a leaking headgasket.
Old Aug 18, 2009 | 03:14 PM
Matt Gruber's Avatar
Matt Gruber
pressure test the cooling system.
coolant in the oil is bad. it will blow it up.
change the oil, put it in a clear jug, let it sit overnite; maybe u can see it separate.
To Head Gasket Problems??
