Trailing arm shim pin question
Old Aug 17, 2009 | 05:48 PM
blueray72's Avatar
blueray72
Default Trailing arm shim pin question
I'm going to drill the housing for the shim pins. Can someone post a pic of where they drilled? Also, do I have to worry about the trailing arm smashing the pin when the full load is removed?
TIA
Old Aug 17, 2009 | 06:09 PM
Rally68's Avatar
Rally68
I put the T/A bolt in place and then put shims in position against the inside walls of the frame pocket. This makes it (fairly) easy to locate your holes. You are drilling from the outside, and you can't really see, but you should be able to feel and visualize where to drill. I drilled 1/4" holes, and the holes in the shims are quite a bit larger, so you don't have to be perfect.
Either buy 2 sets of cotter pins or just use some safety wire to hold the shims while you are driving to the alignment shop
Old Aug 17, 2009 | 06:19 PM
blueray72's Avatar
blueray72
Oh, I thought the pin had to go on top of the shim..duh, run the pin through the shim.
Old Aug 17, 2009 | 08:32 PM
Mike Ward's Avatar
Mike Ward
Your frame already has the hole for the cotter pin..............
Old Aug 17, 2009 | 09:13 PM
72LS1Vette's Avatar
72LS1Vette
Might be a good idea to invest in an A.I.M. (Assembly Instruction Manual).
Rick B.
Old Aug 17, 2009 | 09:19 PM
blueray72's Avatar
blueray72
Ok I'm havin a seriouse blonde moment
just went and looked, and what do ya know. Theres the holes for the pins. I can't beleive I missed that and..... now I remember looking at the pins in the plastic bag and going, "what were these for?". .Crap I bet I threw them away..geez
Thanks peope
To Trailing arm shim pin question
