A/C Liquid line
Old Aug 19, 2009 | 03:08 PM
Carl79's Avatar
Carl79
Default A/C Liquid line
Do I need to remove the radiator to install a new Liquid line on a 79-L82
Also... Is there anything special I should know before I tackle this?
Thanks,
Carl
Old Aug 19, 2009 | 04:30 PM
cowjazz's Avatar
cowjazz
I need to install a new one on my '79, and I see no way to attach the new liquid line to the condenser without removing the radiator core support. The liquid line runs between the core support and the wall of the engine bay. The fitting to connect the liquid line to the condenser is fixed. It appears the entire line will have to be rotated to screw into the condenser, and it seems impossible to do that without removing the condenser and radiator support. So, if you have to remove the radiator core support, the radiator is coming out with it.
The only other thing I can think of is there are two liquid lines for a '79, one for early '79 and one for late '79.
I hope someone tells me I'm wrong, because I've been putting this off due a lack of desire to remove the radiator core support.
Old Aug 19, 2009 | 09:59 PM
Artsvette73's Avatar
Artsvette73
The nut on the line should be free. Think about it how would you tighten the line to the condenser? They tend to lock up on the line due to corrosion. You can slide the line down to the condenser without removing the radiator or support.
Old Aug 19, 2009 | 10:21 PM
cowjazz's Avatar
cowjazz
The old line was boogered durring an attempt to disconnect it from the condenser. The source of the said boogering occurred when the nut did not turn. The entire line spun, and kinked due to overzealous torquing.
So, the new line arrived, and nope, the nut does not turn. I'll check again tomorrow to make sure the new line's nut is not corroded and stuck.
Thanks for the suggestion.
Old Aug 19, 2009 | 10:30 PM
Carl79's Avatar
Carl79
Ok, I also believe the nut turns. If so, are you saying I would not need to pull the radiator? Is there anything else I should know? Anything tricky or is it just straight forward? Thanks again
Carl
Old Aug 19, 2009 | 11:21 PM
Artsvette73
Carl
The line can be fished through the rad. support and the fender skirt. Just make sure you don't crossthread the fittings.
Old Aug 20, 2009 | 08:49 AM
cowjazz's Avatar
cowjazz
Yeah, if the nut turns, then I see no need to remove the radiator.
Old Aug 20, 2009 | 01:32 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
It was a major pain to do it in the last Pace car I worked on.
Wound up having to remove rt side core support bolts and rt hood hinge. Then gently pry between core support and fenderwell till I could slip the line down between them.
I could not fish it through from below& through grill or from top down.
You're talking about the aluminum line from condensor to switch on the fender, correct?
flex hose from compressor to condensor was no trouble at all
Old Aug 20, 2009 | 03:39 PM
Carl79's Avatar
Carl79
Yes, thats the line I'm refering too. I think I'm gonna order the line and try it. I'm hoping for nice cold air after that !!!! I'll let you know how I make out.
Old Aug 20, 2009 | 04:02 PM
cowjazz's Avatar
cowjazz
Please keep us posted. I'm interested in knowing if your new line is for an early or late '79, the manufacturer of your new line, and weather the new line allows the nut to turn.
Old Aug 20, 2009 | 04:10 PM
piperkansas's Avatar
piperkansas
Is it possible to have a local shop make the line?
Old Aug 26, 2009 | 12:41 AM
AzMotorhead
Local shop can make the line if they have a special flaring tool.
Old Aug 26, 2009 | 09:10 AM
cowjazz's Avatar
cowjazz
I took my replacement liquid line and factory line to a machinist that is making a bracket for my ZZ4 engine. He looked at the end of the lines that attach to the condenser. The nuts do not turn. The best he could tell there are multiple swages of different diameters on the end of the line that prevent the nuts from turning.
Old Aug 29, 2009 | 08:42 PM
Carl79's Avatar
Carl79
Just got the line today.....all nuts turn !!!! now feeding it through will be another matter.
Old Aug 30, 2009 | 05:51 PM
Carl79's Avatar
Carl79
Ok.... job is completed !!! You will swear more than a few times because it's very difficult to aim the lines up with out cross threading. You will also need a small pair of hands. There is just no room to get to the fastener off the condenser. Be patient you'll get it. I did not need to remove any part of the radiator or housing other than the fender air intake which sits next to the liquid line. Now I need to charge the unit.
Old Aug 31, 2009 | 08:51 AM
cowjazz's Avatar
cowjazz
Great news! So, where did you obtain your liquid line, and was it for an early or late '79?
Old Aug 31, 2009 | 06:51 PM
Carl79's Avatar
Carl79
I believe it was early79 It's the one before the inlet. Try Riks corvettes for best price. I paid to much for mine around $90.00. Riks has it for less
Old Aug 31, 2009 | 09:40 PM
cowjazz's Avatar
cowjazz
I'd pay double that for a nut that turns, and the ability to avoid removing the core support. I'll give Riks a call. Thanks!
To A/C Liquid line
