Bad Coil?
Old Aug 20, 2009 | 08:21 PM
benito's Avatar
benito
Default Bad Coil?
69 w/stock distributor.
I'm not getting a spark. I think the coil may be bad. Is there a way to test a coil?
Old Aug 20, 2009 | 09:08 PM
...Roger...'s Avatar
...Roger...
I don't think I ever tried to test just a coil for spark, I have several used ones I just swap if I suspect a bad coil.
If I had to guess on a way to do it I would say put 12 volts the pos term , put a coil wire in the center and position the other end 1/2" from ground, then attach a wire to the neg term and with the other end of the wire quickly scratch ground and watch for the arch at the coil wire. Thats just a guess.
Old Aug 20, 2009 | 09:22 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Ya beat me to it, Roger.
Old Aug 20, 2009 | 09:26 PM
benito's Avatar
benito
Thanks guys ... I'll give it a try tomorrow.
Old Aug 20, 2009 | 09:27 PM
...Roger...
I learned that from you.
Old Aug 20, 2009 | 10:08 PM
terry82's Avatar
terry82
i would check to see if you are getting power to the coil .
Old Aug 20, 2009 | 10:26 PM
PuddleJumper's Avatar
PuddleJumper
oh there is an ez way and that is put an spark plug in it and see if it arcs. um if i can find it there is an youtube video that explains this
Old Aug 21, 2009 | 12:07 AM
benito's Avatar
benito
I do have 12 volts to the coil. Thanks
Old Aug 21, 2009 | 12:10 AM
benito's Avatar
benito
Would that be to put the bare boot end of the plug in the coil and ground the threads of the plug?
Old Aug 21, 2009 | 12:19 AM
PuddleJumper
yah so it kinda acts like as if it were an "coil on Plug"
i have seen it work before
Old Aug 21, 2009 | 12:39 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
The plug still needs a return path for it to be able to develop a spark. This means the threaded part must be grounded against the block or some other ground when cranking.
Solve this easily through Process of elimination: you already know you have power to the coil. Use one of the plug wires in place of the coil wire and try to start the engine. Of course the cylinder you took the wire from will miss, but:
if the coil is good, the engine will start. - replace coil wire.
if the coil is bad, the engine will not start. - replace coil
Old Aug 21, 2009 | 08:43 AM
...Roger...
What if the wire going to the points is grounded or open ?
Old Aug 21, 2009 | 09:01 AM
RobbSalzmann
St. Jude Donor '12
You make a good point DW. My thought was if he's already had the meter out to check power to the coil, he also inspected under the cap.
The point of my post is demonstrate logical troubleshooting to reach a diagnosis, versus 'guessing' until he gets to the right part.
A lot of time and energy can be spent on hunt-n-peck, where a logical process will quickly lead to a solution.
Old Aug 21, 2009 | 09:36 AM
...Roger...
100% I like working through a problem systematically and finding the exact cause rather than changing 4 or 5 things and wondering what actually fixed it. ( I'm a lot **** that way . )
Old Aug 21, 2009 | 09:46 AM
69427's Avatar
69427
If the OP has 12 volts at the coil+, then a short between the coil and points is unlikely (unless there is also a fault with an open primary winding). Assuming the points are open, there should be 12 volts at both primary terminals.
Old Aug 21, 2009 | 09:52 AM
noonie's Avatar
noonie
Here is the fastest way I found to test. Takes less than a minute.
Take dist cap off and put a known good spark plug on coil wire and lay spark plug on engine ground anywhere.
Turn ignition to on.
Start with the points closed, take a small screwdriver and touching only the moveable part of the points, open the points.
You should see the points arc a little when opening (you know you have power) and also the spark plug will spark (coil is good).
The only variable would be the coil wire.
The coil might not perform well at rpm when hot though.
Old Aug 23, 2009 | 06:32 PM
benito's Avatar
benito
Thanks everyone. The coil checked out fine. My very new points were cooked. I think I must have left the ignition switch on last time I drove the car.
To Bad Coil?
