69 Vette- How to ID Positraction?
I read that posi became standard on all 70 Vettes going forward.
Without having the build sheet, window sticker, and ripping open the differential, can someone tell me how you can identify if a 69 came with Posi Track from the factory.
The VIN code maybe, or a stamp on the rearend possibly???
Thanks,
R
of course this does not tell you how it came from the factory. there is no way unless you have a sticker or a build sheet... I could have been replaced sometime in the last 40 years
My 68 has a stamp code on the bottom of the differential of which I think most vettes have; Here are the codes for the 69 Vette:
1969 Corvette Axle Ratios
Code Ratio Application
AK 3.36 Standard (327/350)
AL 3.08 Positraction (327/350)
AM 3.36 Positraction (327/350)
AN 3.55 Positraction (327/350)
AO 3.70 Positraction (327/350)
AP 4.11 Positraction (327/350)
AS 3.70 Standard (327/350)
AT 3.08 Heavy Duty Positraction (427)
AU 3.36 Heavy Duty Positraction (427)
AV 3.08 Positraction (427)
AW 3.08 Heavy Duty Positraction (427)
AY 2.73 Heavy Duty Positraction (427 Turbo-Hydra-Matic)
AZ 3.55 Heavy Duty Positraction (427)
FA 3.70 Heavy Duty Positraction (427)
FB 4.11 Heavy Duty Positraction (427)
FC 4.56 Heavy Duty Positraction (427)
Note: Most 1969 C3 Differentials were manufactured at Warren and are suffixed 'W'.
1969 models built after approximately August of 1969 use 1970 coded differentials.
Good luck.
ed
