Fiberglass Questions
Old Aug 23, 2009 | 08:04 PM
Kim72's Avatar
Kim72
Default Fiberglass Questions
I want to make some simple speaker enclosures/backs out of fiberglass. I believe I know the basics but I have some questions:
1. Is there something simple to use as a release agent (ie: wax, tape, tin foil, shave cream , etc...)??
2. How many layers will be enough?? Non-structural items.
3. Which resin would be best??
Thanks for any help.
Old Aug 23, 2009 | 08:54 PM
SIXFOOTER's Avatar
SIXFOOTER
Saran Wrap works pretty good
Old Aug 23, 2009 | 08:55 PM
wombvette's Avatar
wombvette
Packing tape works well, but will leave the image of the tape.
Old Aug 23, 2009 | 09:43 PM
BigBlockTank's Avatar
BigBlockTank
You can make a mold from some foam, like styrofoam from home depot for insulation. Test it for compatability with your resin first.
BBTank
Old Aug 23, 2009 | 09:52 PM
The13Bats's Avatar
The13Bats
When I do a fiberglass part the mold is very slick and several coats of mold release wax works fine,
I don't know what you are using for your buck/mold but if it is rather grainy and porous I like to use aluminum foil,
I would still run two layers of mat and be sure to roll out excess resin, you really want just enough resin to wet the mat fully,
To Fiberglass Questions
