72 TCS System/Solenoid testing
Old Aug 24, 2009 | 05:40 PM
72 corvette roadster's Avatar
Default 72 TCS System/Solenoid testing
Hello, I just finished re-installing the original carb on my 72 with manual trans car. I have hooked back up the original tcs system (It had been by-passed by the previous owner), and I am wondering if there is a way to "bench test" the system. The solenoid is in the closed position (no vacuum to dist) normally, and I understand that the solenoid should open when the engine is warm and the trans is in 3-4 gear. Is there a way to test this with one person (ie I cannot have the car running and in 4th gear and inspect the solenoid)? Any ideas? Thank You
Old Aug 24, 2009 | 06:18 PM
MelWff's Avatar
MelWff
get a long piece of hose and a plastic T fitting. Splice the T into the hose going to the distributor and run the line into the passenger compartment through an open window and attach a vacuum gauge.
Old Aug 24, 2009 | 06:26 PM
CCrane65's Avatar
CCrane65
The TCS will not engage on the '72 until 4th gear only. In '71 it engaged in both 3rd and 4th.
To test when the engine is idling and at normal operating temperature unplug the vacuum advance line from the distributor. If the TCS is working properly there should be no change in the RPMs since vacuum advance is blocked at all times except:
Engine temp is below 180 or above 230
First 20 seconds after startup
Transmission is in 4th gear
As mentioned in the above post, you can connect a T connector to the vacuum advance line and run a length of hose into the passenger compartment with a vacuum gauge on the end then shift into 4th gear (keeping your foot on the clutch) and watch for a change in the vacuum gauge from none to vacuum present.
You should also notice a distinct change in engine rpms.
cc
Old Aug 24, 2009 | 06:31 PM
CCrane65's Avatar
CCrane65
I'm not sure why you want to enable the TCS system. It is intended to raise the engine temperature by blocking vacuum advance in order to lower emissions. A feat it fails at miserably. Lowering emissions that is. It definitely blocks vacuum advance.
You are essentially purposely keeping your engine in a retarded state while increasing the load on it.
cc
Old Aug 24, 2009 | 06:44 PM
Vetteaddiction's Avatar
Vetteaddiction
My '72 Lt-1 had the same system. You can take it for a test ride and actually hear when the vacuum advance is allowed to the distributor, after a 23 second delay in 4th gear. You should also have advance at idle before the engine warms up, less than 82 degrees (if you disconnect the hose to the advance the RPM should drop).
There's an excellent description of the system in the Service Manual, page 6T-7.
I'm sure others can elaborate,
Good Luck, Chris
Old Aug 24, 2009 | 09:57 PM
cc
Thank you for the response. A few reasons why I hooked it back up...I am going for a 100% original engine bay. Also, I understand that it will raise the temp at idle, however, my understanding is that it should not really have a big negative effect on performance as the dist. timing advance is dominated by the mechanical aspect as soon as you apply throttle (ie no vacuum when throttle is open). My understanding is that there could be a slight negative impact on immediate throttle response from closed throttle cruising in low gears to wot. My carb was restored by Phil Cancilla (custom rebuilt carbs in Jersey) to an excellent standard I must say. It runs and looks beautiful and I would highly reccomend. One small issue is that it had a idle speed slightly too high (even with idle stop screw backed out), and with a quick call to phil (agian, excellent customer service), he explained that the carb was restored exactly as original, and one way they (GM) tried to reduce emmisions was to increase airflow at idle (ie butterfly more open) and compensate with retarded timing. Thus he suggested hooking back up the solenoid reducing advance, and the idle was perfect at his factory settings. What do you guys think?
Old Aug 24, 2009 | 10:01 PM
Good Luck, Chris
Thank you for the response. There is no vacuum advance being fed to the dist., through the solenoid at cold start-up. Would you say this is most likely the solenoid, the relay, temp sensor? Any opinions or experience?
Old Aug 24, 2009 | 10:17 PM
CCrane65's Avatar
CCrane65
The temp sensor controls start up and high temp situations. There will be no vacuum advance above 82 degrees or below 232.
cc
Sorry, I had that backwards. It's correct for a big block now according to the service manual. Small blocks only check for above 82 degrees.
Old Aug 25, 2009 | 10:39 AM
Vetteaddiction
On a cold engine the vacuum advance solenoid should be energized (open, allowing vacuum), if not - ground the wire from the cold terminal of the temperature switch. If solenoid energizes, replace the temperature sending unit.
You could also have a bad vacuum advance. Bypass your solenoid and plug it into the port on the carb. If you get advance it's working.
If both these tests are good, it sounds like you have a bad TCS solenoid. But get the service manual, it steps you through the entire process.
Chris
Old Aug 25, 2009 | 11:55 AM
CCrane65's Avatar
CCrane65
You do have the temperature switch in the passenger side head connected with a green TCS jumper harness correct? And that jumper harness is connected to the blue wire that exits the engine harness between the firewall and passenger side head?
cc
To 72 TCS System/Solenoid testing
