Automatic tranmission issues
Old Aug 26, 2009 | 07:20 PM
iceref63's Avatar
iceref63
Default Automatic tranmission issues
I purchased a 69 vette (in pieces) and am in the process of putting it back together. My AT does not to want to shift into any gear period. Any ideas of where to start? Thanks in advance.
Old Aug 26, 2009 | 07:31 PM
SIXFOOTER's Avatar
SIXFOOTER
so its running and the shifter moves but the tranny will not drop into gear?
Fluid level, filter new? How old is the tranny? MIles?
Old Aug 26, 2009 | 08:26 PM
iceref63's Avatar
iceref63
Problem solved (at least this one). Low on tranny fluid. Lesson learned...never overlook the odvious and never assume.
Old Aug 26, 2009 | 09:00 PM
Oldguard 7's Avatar
Oldguard 7
Is it leaking at all? Last month my tranny was leaking and I did not see any fluid on the dipstick. I filled it up to its normal level and the tranny shifted fine for a while and then suddenly it left me stranded (would not shift into any gear) I later found that the speedo driven gear sleeve seperated from the tranny and had fallen out. The fluid was leaking from this area. The reason the sleeve came apart from the tranny because the retainer (a $ 3.00 part) was missing. Anyway, I installed a new tranny (after I reconnect the driveshaft and cables) and will be back on the road next week. Glad you found the cause.
To Automatic tranmission issues
