HEI Distributors
Old Aug 27, 2009 | 01:21 PM
DanielA's Avatar
DanielA
Default HEI Distributors
Does anyone know:
1. How much mech advance a stock HEI distributor should provide.
2. At what RPM should the stock unit be "all in."
My 1977 L82 unit seems to provide only about 16* and is "all in" at only 1800 rpm. I am pretty sure it is stock, but everything else I have read seems to indicate that the factory set up isn't all in until much higher (redline) rpms. I get the same results using the factory weights and center plate with the heavy springs from the MR gasket kit.
Old Aug 27, 2009 | 05:15 PM
batmedic's Avatar
batmedic
Check out the "sticky" post above about timing. He explains your question in great detail. I believe that 1800 rpm is where you want it from that article.
Old Aug 29, 2009 | 07:32 PM
DanielA's Avatar
DanielA
I did read the Sticky in great detail. I originally posted a question there but got no responses. I think 1800 is too low. According to what I have read, I don't want to be all in until 2500. Also, I think HEI distributors are supposed to give 20* of advance. Mine is only about 16* Since I believe my car is stock, I wonder if these numbers are typical, or if something else is going on.
To HEI Distributors
