Power brake conversion
Old Aug 27, 2009 | 01:31 PM
snmnjones's Avatar
snmnjones
Default Power brake conversion
I am swapping over my manual brakes over to power brakes on my 71 C3.
I am in the middle of a body off restoration. Does any one have a recommendation for a chrome booster and reservoir. What size brake lines should I install? I plan on going back with stainless lines. As you may guess I am not keeping the car original. I plan on driving and enjoying it.
Old Aug 27, 2009 | 01:48 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Since you're not after originality, then it's best to consider a hydroboost instead of the stock vacuum booster, I did that swap in my '71 and now I can say it has the best brake response of any care I've ever driven.
Old Aug 27, 2009 | 04:21 PM
Gordonm's Avatar
Gordonm
I'll second the hydroboost. Way better than the vacuum system. It sucks(pun intended). The hydroboost is smaller and more efficient than the vacuum cannister.
Old Sep 4, 2009 | 09:07 AM
snmnjones's Avatar
snmnjones
Thanks. I will look into the hydroboost
To Power brake conversion
