78 Fuel line changing procedure.
Old Aug 28, 2009 | 05:48 PM
ixlor8's Avatar
ixlor8
Default 78 Fuel line changing procedure.
I would like to replace the hoses coming from the passenger side frame to the fuel pump. I have purchased a "S" Molded fuel hose with clamps.
How do I change this?
How much gas comes out of the gas line and the vent hose?
Any helpful tips? ( I do not want 5 gallons of gas on the ground .)
Old Aug 28, 2009 | 06:15 PM
72LS1Vette's Avatar
72LS1Vette
A 78 should have a top-feeding connection at the tank. If you disconnect the hoses at the tank you will only drain whatever is left in the lines and not siphon anything else out. When you restart the car it may crank longer than usual to fill the fuel line before starting.
Rick B.
Old Aug 28, 2009 | 06:20 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Do it in an area with very good air flow and NO SPARKS or electrical equipment that can spark on start up.
Jack up the front of the car and safely support it.
You are going to get gas on you and there is no way around it.
If the tension clamps are still on your hoses, move them back onto the hoses. If you have jewel clamps ...do the same thing.
Have your new hoses set up with the tension clamps already installed back far enough on the hose so you can slip the hose on the line and then move the tension clamp into the correct area for sealing. The tension clamps are fine and will seal due to this is not a high pressure area. NO need for jewel clamps. If using jewel clamps, do not overtighten them or you can damage your new hoses.
Pull the hoses off and then install the new ones. Some fuel is going to drain out due to the reservoir in the fuel pump. And will eventually stop but may also require you to loosen your fuel cap so if pressure is in the tank it will not siphon it out while working on it.
Start to finish it is about 1/2 hour if that.
"DUB"
Old Aug 28, 2009 | 08:48 PM
ixlor8's Avatar
ixlor8
Thanks for your help guys!
Old Aug 30, 2009 | 10:56 PM
ixlor8's Avatar
ixlor8
Default Update
Key to not having a lot of gas spillage.
++++ Removed battery leads ++++
1) I did not drive the car for a day. No PSI in system.
2) Raised front of car.
3) Removed Gas cap.
4) Replaced vent line.
5) Replaced fuel line - Lost 5-6 drops of gas.
6) Use fuel injection clamps.
Worked great!
To 78 Fuel line changing procedure.
