Headers 74 Suggestions?
Old Aug 29, 2009 | 10:32 AM
BIGJIM13's Avatar
BIGJIM13
Default Headers 74 Suggestions?
Guys
need to replace the headers on my 74.. has anyone found a good set that will still bolt up the accessories like air conditioning brackets and such?
Old Aug 29, 2009 | 11:05 AM
Ganey's Avatar
Ganey
You should state at least BB or SB.
Old Aug 29, 2009 | 03:05 PM
BIGJIM13's Avatar
BIGJIM13
Sorry ...standard SB
Old Aug 29, 2009 | 05:10 PM
outlawkinser's Avatar
outlawkinser
If you've got a SB, I used a set of Hooker Super Comp's #2134. Everything hooks up with no problem. For the AC bracket, I followed the instructions on page 2 of the Technical Information Instructions.
http://www.holley.com/data/Products/Technical/2134HKR.
Last edited by outlawkinser; Aug 30, 2009 at 01:07 PM. Reason: Moved reply from "General" posting.
Old Aug 29, 2009 | 07:02 PM
Ganey's Avatar
Ganey
Both Hooker Super Comps & Dynomax Cerama-Coat Headers are very good. The Dynomax Corvette SB Cerama-Coat headers fit & flow great, much better than is commonly known. I have been rec. them & many have them now.
Mine came w/ a different compressor than yours & now has a non stock compressor.
Old Aug 29, 2009 | 07:52 PM
TopGunn's Avatar
TopGunn
I have Ceramic Flow Tech. Bolt up perfectly. You'll have to make some spacers for the A/C bracket, but not a big deal. I used some Gal. steel pipe.
Old Aug 29, 2009 | 09:35 PM
Al Davis's Avatar
Al Davis
Default Hookers
Hooker Super Comps
To Headers 74 Suggestions?
