And the next snapped off part is......
Old Aug 29, 2009 | 08:17 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default And the next snapped off part is......
the turn signal lever, snapped off flush with whatever it is connected to.
How hard is it to fix this one, and how do you fix it ?
Gonna have to lay off the gym for a while, costing me too much in broken stuff
Old Aug 29, 2009 | 08:38 PM
wnmech's Avatar
wnmech
It sounds to me like the steering wheel is going to have to come off. It's not to bad of a job. Pull up Jim Shea's corvette steering papers and you will be able to follow his diagrams and tips. If your 80 is similiar to my 77 tilt/tele wheel you will be able to use common hand tools with the exception of going to A/Zone and renting their steering wheel remover and locking plate removal tool. Just pay attention to the horn button and attaching shims and rod.
Old Aug 29, 2009 | 09:55 PM
TimAT's Avatar
TimAT
First time that's ever happened. j/k
You might be able to remove the broken piece with a good needle nose pliers. Sometimes there's just enough left to get a grip on it. If not, it's tear down time for the column. IIRC, the lever goes into the wiper switch. Just tear it down far enough to get to the back of the wiper switch, and you can push the broken stub out. Not easy, but not as bad as some things are either.
Old Aug 29, 2009 | 10:17 PM
MotorHead's Avatar
MotorHead
So since I pushed that piece in as far as it will go and then epoxied the lever back into the hole I am pretty well screwed now if that doesn't work
Old Aug 29, 2009 | 10:40 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
........Is your horn working yet ?
Old Aug 29, 2009 | 10:44 PM
MotorHead's Avatar
MotorHead
One thing at a time, you have to prioritize, it goes fast and stops good
Old Aug 29, 2009 | 10:53 PM
vettecrazy88's Avatar
vettecrazy88
Can you EZ out it? Or drill and chase the threads
If it goes fast and stops good you don't need turn signals. Or the rear view mirrors.
Good luck
Old Aug 29, 2009 | 10:56 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Who needs blinkers and a horn when you have arms, a finger and a mouth !..
Old Aug 29, 2009 | 11:07 PM
MotorHead's Avatar
MotorHead
Just remember guys, it "Motor"head not TurnSignalHead or HornHead,
btw I can figure this stuff out easy, it is just faster to get answers here and there is usually an easier shortcut way of doing something someone has figured out
Old Aug 29, 2009 | 11:16 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
..That's one of the reasons that we are here.
Old Aug 29, 2009 | 11:21 PM
LFZ's Avatar
LFZ
JB Weld man....
Old Aug 29, 2009 | 11:24 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Originally Posted by American Psycho
JB Weld man....
No, hes gotta get that out....If the epoxy is too bad in there, he's going to have to take the column down like Tim said....Bad move on the epoxy. You could have got that nub out w/o a tear down.
Old Aug 30, 2009 | 12:06 AM
MotorHead's Avatar
MotorHead
That nub wasn't coming out, it was broke flush, it also pushed right back easy, is it supposed to be threaded ?
We'll see tomorrow. If what I did worked it took me 5 minutes and I might change my forum name to TurnSignalMan
If not I have to fix the the horn anyway so I'll be up to elbows into the steering column, good thing Corvette Central has a free shipping offer this weekend
Old Aug 30, 2009 | 12:19 AM
TimAT's Avatar
TimAT
Kind of bad news. It's NOT threaded in. It just kind of snaps in. And it goes into the wiper switch, so if that's fubar you'll need a wiper switch too.
Old Aug 30, 2009 | 12:31 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Jim Shea has a paper that explains how to remove the nub, EVEN IF IT IS BROKEN FLUSH.Did you download his papers yet ?..They are a must have !...
Old Aug 30, 2009 | 12:32 AM
MotorHead's Avatar
MotorHead
Yeah I just saw a picture of one and you are right it is not threaded and you are also right I am looking at a new switch. Only problem Corvette Central seems to have the switch but not the lever
Old Aug 30, 2009 | 01:26 AM
Solid LT1's Avatar
Solid LT1
First lets straighten something out, Tilt-tele column has threaded in turn signal lever, Std column has bolted on lever that will require you to pull wheel, adapter, lock plate to get to the screw that secure lever to turn signal switch. If you have Tilt-tele you should be able to reach in with needle nose pliers and unscrew lever. Hope this helps you out, good luck!
To And the next snapped off part is......
Old Aug 30, 2009 | 08:02 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Wayne, you need to get back to work, so you stop breaking things. Good luck with the repair.
Old Aug 30, 2009 | 09:01 AM
Jim Shea's Avatar
Jim Shea
Try the tips in this paper. The lever plugs into the dimmer pivot. You should be able to get the stub out of the pivot without disassembling the steering column.
http://jimshea.corvettefaq.com/wp-co...al21au2005.pdf
Jim
Old Aug 30, 2009 | 09:16 AM
stpman's Avatar
stpman
Jim is this part used only in the Vette or was it shared around the other car lines?
MotorHead
If it was shared around I might be able to help you out with parts I have a bout a dozen different columns at the shop as well as a couple turn signal switches in the tool box
Steve
