Rear end clunking noise
Old Aug 31, 2009 | 08:56 AM
Chadborne's Avatar
Chadborne
Default Rear end clunking noise
I have a 70 454, 4 spd that makes a clunking sound, but only when starting out in 1st gear and after it has been driven for a while. Someone said it sounds like the rear end clutch has gone bad. The drive axles appear to be ok, so I don't think the noise is from them. No noise when in 2nd thru 4th. Appears to make noise when torqued in 1st and after it has warmed up. Any help will be appreciated.
Old Aug 31, 2009 | 09:11 AM
Spot Rot's Avatar
Spot Rot
If your car is pointed directly straight, it's not the clutches.
If it only happens when your car is taking off from a stop but is turning a little, the it's likely the clutches - but that doesn't necessarily mean they need replacement.
Old Aug 31, 2009 | 09:14 AM
uncle phil's Avatar
uncle phil
Someone told me that the GM posi-trac additive will take care of that chattering if it is the clutches. Might want someone elses opinion, but mine is doing the same thing and I'm getting ready to add some along with some Royal Purple.
Old Aug 31, 2009 | 09:16 AM
uncle phil's Avatar
uncle phil
I meant to say the differential
Old Aug 31, 2009 | 11:14 AM
71 Green 454's Avatar
71 Green 454
Originally Posted by uncle phil
Someone told me that the GM posi-trac additive will take care of that chattering if it is the differential. Might want someone elses opinion, but mine is doing the same thing and I'm getting ready to add some along with some Royal Purple.
Do a differential fluid change with the recommended fluids.
Old Aug 31, 2009 | 02:12 PM
Drizzle's Avatar
Drizzle
I agree
Mine sounded like a 2,000 dollar problem, and changing the diff fluid fixed it up for under 25.00. Amazing.
Old Aug 31, 2009 | 02:47 PM
Mikey74Stingray's Avatar
Mikey74Stingray
Originally Posted by Drizzle
I agree
More like $60.00 Thats how much the stuff cost me from the Stealer dealer.
It works though. I had the same problem. a fluid change fixed it.
Old Sep 2, 2009 | 03:23 PM
Chadborne's Avatar
Chadborne
Default Rear End Clunking Noise
Thanks for the info all of you sent it. I have the GM Lube on order.
Can you tell me if the differential on a 70 has a drain plug or do I need to pump it out the side fill plug?
Old Sep 2, 2009 | 04:25 PM
TimAT's Avatar
TimAT
No drain plug. Sorry. either you split the case, suck it out thru the fill, or install a drain plug.
While you're under the car, look at the front snubber cushion, shock mounts, crossmember cushions, U-Joints, strut rods, and sway bar mounts. Any of those could also cause a clunk. Most likely the front snubber.
Old Sep 2, 2009 | 09:42 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Be careful. I had a clunk in the rear on my 72. Started to fix it. I said "while Im at it I might as well"...................
$18,000 and 3 years later I was the proud owner of a frame up restored numbers matching correct L48 automatic 1972 corvette.
Old Sep 3, 2009 | 12:55 AM
Racer11's Avatar
Racer11
GM additive and Super Tec synthetic blend gear oil from Wal Mart,,,,super quiet
Old Sep 3, 2009 | 01:11 AM
Peterbuilt's Avatar
Peterbuilt
63mako, I understand how that can happen but to the OP just change the lube and GM additive and make a few figure 8's at low speed and see if that helps. Then you'll have $17,940 left to do other stuff. PG.
Old Sep 3, 2009 | 08:36 PM
myk7's Avatar
myk7
I've had ring gear bolts back out and start smacking the housing.. finally knocked a hole in the housing, lost the fluid, lost the rear end.
Old Sep 4, 2009 | 11:19 PM
63mako's Avatar
63mako
Old Sep 5, 2009 | 01:19 AM
johnnybrewmeister's Avatar
johnnybrewmeister
Originally Posted by 63mako
Yep, scary.
Keep us posted on the progress Chad...I may be in the same boat. Mine's been making a "clunk" when starting from a stop and turning right. Been that way for years and I've always hoped it wouldn't turn into an 18K re-do. Redo of rear gear oil is prolly in order anyway.
To Rear end clunking noise
