Fuel gage bounces
Old Sep 2, 2009 | 09:15 AM
ED79's Avatar
ED79
Originally Posted by DWncchs
Ed I missed your thread yesterday for some reason. I think at this point since the gauge is out it might be best to send your gauge to Willcox and let him test it.
I had one something like this in a 71. New tank,new aftermarket sender and a new aftermarket gauge. The gauge was foreign and was the type that "did not" use the resistor across the back of the gauge. Ended up having the original gauge rebuilt and replacing the sender with either an AC or one from Quantas (can't remember which one ). This fixed the problem. This doesnt help you but I did recognize a difference between a very fast needle that follows every move of the sender and a needle that flicks back and forth between E and F. The flicking is one problem and the very fast needle is another. Recognizing the difference is important.
The "improved ground" that Noonie mentioned has me wondering if a semi-poor ground could hide a gauge with poor dampening.I'm going to the garage and will attach a variable pot on the ground side of the gauge and see if this will drastically effect the accuracy of the gauge. If this wont effect the accuracy then its possible it can mask a bad gauge.
( Ernie I will have to cut into the series of pots to control both sides but I'll put it back. )
Thanks DW, I missed you yesterday but figured you took the day off.
Well at this time I'm really thinking about R&R the sending unit
because I don't know what else to do (but still thinking) and have to start somewhere. I just hate to throw good money away when it can be used somewhere else. Thanks again ED
Old Sep 2, 2009 | 09:21 AM
...Roger...'s Avatar
...Roger...
I wish we could isolate the problem to either the gauge or the sender. If you want to spend a couple bucks you could go to Radio Shack and get a potentiometer to take the place of the sender in the tank and control the dash gauge from the rear deck and watch the dash gauge through the back window and see if it reacts the same. Just a thought.
Old Sep 2, 2009 | 09:24 AM
...Roger...
I was in and out of the forum all day long and posted to your thread earlier in the day but somehow missed it as the day went on.
Old Sep 2, 2009 | 09:33 AM
CCrane65's Avatar
CCrane65
FWIW, I had a fuel gauge that bounced a lot on my '65 and it turned out to be one of the ribbon cables on the sending unit. It was holding on by a thread having rusted through 99% of the metal. As the gas moved in the tank so did the ribbon cable varying the amount of voltage that was transmitted to the gauge.
cc
Old Sep 2, 2009 | 09:51 AM
ED79's Avatar
ED79
cc
Thanks CCrane72
I was wondering myself if there could be sometype of connection break down inside the tank on the sender and that was why I was thinking of pulling it to check. So at this point I may go to Radio Shack per DW and see what I can find to check it on the tank.
Thanks again to both ED
Old Sep 2, 2009 | 10:41 AM
...Roger...
OK I found something. I set a gauge up and using the pot setup Ernie sent me I set the needle to 1/2 tank- full power on the 12 volts in to the gauge-- full and solid ground to the gauge cluster
Then I removed the ground (same as the ground to the tank) and put a pot in between the gauge and ground so I could vary the ground.
I then rotated the ground pot up to 50 ohms-this only changed the needle by 1/8 tank so this wont effect the accuracy too bad.
Then using the first pot that varys the input to the gauge (what comes from the tank sender) I started rotating it back and forth to make the needle go from E to F.
With the resistance up on the ground side the speed of the needle is much much slower.
To me this means a poor ground at the tank sender can mask a bad gauge."Bad" gauge from the standpoint of dampening even though it reads accurately.
My thoughts are Noonies gauge has poor dampening capability's but probably reads accurately sitting still but when he soldered the ground in made a better connection to ground and increased the sensitivity of the gauge movement.
Old Sep 2, 2009 | 10:54 AM
...Roger...
Ed do you still have the gauge out of the car ? If you have put it back in it would be great if you could go to the Shack and get a variable pot and put it between ground wire at the tank and the sender. Dial it up and see if that slows down the needle bouncing. If it does it might explain some things.
Old Sep 2, 2009 | 01:41 PM
ED79's Avatar
ED79
OK DW the gauge was almost in but was able to wire it up,went to radio shack. Did the hook up from ground on the tank to potentiometer, next unhooked sender wire from tank and ran a wire from sender wire to the pot (had pot ohms set at 89). Turned on switch and fuel gauge went to approx 1/2 tank, then I rocked the car front to rear fairly hard and the needle never moved. Did this a few times, so I thought, well let's do the factory hook-up one more time to see---it still bounced!!
Retested it again with pot and no movement. Can I now assume that it is the sender that's bad?????????? ED
Old Sep 2, 2009 | 03:09 PM
...Roger...
Let me get this straight. You put the pot between the sender wire and the ground wire at the tank ? In other words bypassing the tank unit. If so that is taking the place of the sender in the tank so rocking the car would not change anything.
If this is how you hooked up the pot try rotating the **** back and forth quickly and watch the needle and see if it follows smoothly or is bouncy. If its bouncy the problem is going to be in the gauge.
Old Sep 2, 2009 | 04:36 PM
ED79's Avatar
ED79
Yes this was the way I tried it but at the moment I have the sender unit out and with the tester checking the ohms as I slowly raise the float, the ohm readings are bouncing up and down or erratic, not smooth. Does this help prove anything or do I just need to stop and have a drink? ED
Old Sep 2, 2009 | 05:05 PM
...Roger...
Your reading should be smooth. Make sure your connections are good. Also try connecting your leads closer to the pot and see if one of the connections is loose.
Old Sep 2, 2009 | 06:54 PM
ED79's Avatar
ED79
Thanks again DW
As mentioned, the sending unit is on the workbench. When doing this float test with the ohm meter, as I raise the float slowly I see some up and down readings as I continue up (Not using the POT on the bench test at this time) which could be causing the fuel gauge to bounce from these readings? I agree with you that it should be smooth and it's not, does this raise an eyebrow that we should continue testing or consider a sending unit? Just a thought......Don't give up on me!!!!! ED
Old Sep 2, 2009 | 08:24 PM
  #33
...Roger...
Thanks again DW
Definitely not giving up,its just starting to get fun.
I wonder if it would test any different when its in fuel ?
When I mentioned getting your leads closer to the pot I actually was referring to the rheostat or pot in the sending unit (not sure what the correct name is for it ).
What readings you are getting ? We know somewhere between 0-90 is what it should read. Can you describe your readings ? For instance 0 5 10 15 20 "90" 40 50 ? Or and this is the one I suspect 0 5 10 15 20 175 40 50 ? The 175 reading will drive the needle crazy.
Old Sep 3, 2009 | 08:50 AM
  #34
ED79's Avatar
ED79
Well I just did an ohms test on the sending unit in a bucket of fuel and as I slowly lowered and raised the float, with my ohms meter I saw no signs of erratic bouncing like 25 35 41 102 50 145 55 90 etc. as I did yesterday with the unit being dry. it was smooth....
Old Sep 3, 2009 | 09:03 AM
  #35
...Roger...
Have you tried hooking the sending unit up to the car wiring outside the tank and operating it and watching the needle ?
Then you can hook the Shack pot up and do the same and see if there is a difference.
I'm leaning towards the gauge being the bouncing problem at this point.
Old Sep 3, 2009 | 09:34 AM
  #36
ED79's Avatar
ED79
Yes me to because I just did the hook up outside of car and when I created waves in the fuel bucket of coarse it started bouncing. Corvette Central has the fuel gauge for around $65+ S&H and we're not sure that could even be in the circuit board. Did you notice in an earlier thread of the gauge ohm readings, what did you think? Is this dampening in the gauge or resister?? Thanks again ED
Old Sep 3, 2009 | 10:35 AM
  #37
...Roger...
The dampening is mechanical and is in the gauge. I described it in an earlier post. I saw your ohms readings and if I have time i will compare to one of the gauges in the shop.
To Fuel gage bounces
Old Sep 3, 2009 | 05:51 PM
  #38
ED79's Avatar
ED79
Thanks Dwncchs for all your help and advice. I'm kinda tired the situation now and I guess it's time to buy parts. Will update when it's fixed. Again thanks ED
Old Sep 3, 2009 | 11:59 PM
  #39
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hey Ed and Roger..
I'll try to look this over tomorrow and see if I can help.
Ed, if you have the gauge out and want to send it to me, I (my shop, right now I can't do diddle) can test it in about 5 minutes. No charge!
Let me look this entire thread over and I'll try to post again tomorrow. Don't go spending money unless you need to!
Willcox
Old Sep 4, 2009 | 04:06 AM
  #40
Greg73convertible's Avatar
Greg73convertible
[QUOTEcan test it in about 5 minutes. No charge! But let me look this entire thread over and I'll try to post again tomorrow.
Willcox
][/QUOTE]
With respect to other vendors, this is why I buy from wilcox
