Knock off dynamat opinion?
Old Sep 2, 2009 | 05:50 PM
wiseman79's Avatar
wiseman79
Default Knock off dynamat opinion?
I came across this knock off brand dynamat sound/heat insulator, was wondering if anyone has seen or used it. It's pretty cheap, 100 sq feet should be enough to do the Vette and my Mercedes for $160, real dynamat would be like 4 times the price. I'm not into big stereos or anything, just after a quieter, tighter interior.
Ebay Link
Hmmm, just found this one too, 100 sq feet for $95. Too cheap to be good?
Link 2
Old Sep 2, 2009 | 06:40 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
The products in those links looks like that is rolled asphalt that you can buy in any home improvement store. It is used in roofing/flashing applications. Dynamat is basically the same material as asphalt roofing shingles. I have done the reflectrix route and will never do that again. Way to time consuming and the spray route looks like the way to go. You can get into all nook and crannies and behind the door pillars too. The spray method will work great on the doors also. Lizard Skin and Dynamat both make spray on sound deadeners and heat barriers. The Lizard Skin guys are 2 different applications and the Dynamat is all combined into 1. The Dynamat spray on recommends almost 3/4" (.70)thickness. At 3/4" thickness with Dynamat you should be able to hear the radio as you go down the road. The Dynamat is cheaper then the other product and the application wand is a 1/3 the price, houstonvett
Old Sep 2, 2009 | 06:41 PM
redman76's Avatar
redman76
St. Jude Donor '09
There may be a difference, but I bought a similar product called B-Quiet at a fraction of the cost of Dynamat. I did a side-by-side visual comparison and they looked the same to me. I covered my entire interior with this stuff and it really helped with temps and noise. I'm not sure I answered your question, but I think there are cheaper products out there that are just as good as dynamat IMHO.
Old Sep 2, 2009 | 06:54 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i have used the e-dead and it works fine. to get it to really stick well and form good use a roller and a heat gun. i think it comes in a few thicknessesn also.
Old Sep 2, 2009 | 07:03 PM
LT1driver's Avatar
LT1driver
why is the shiny silver reflective side up??????? it should go down to reflect heat from entering cabin, that is the way home attic insulation is done.
Old Sep 2, 2009 | 07:26 PM
wiseman79's Avatar
wiseman79
I may give this a shot then. Side Pipes + Convertible + highway speeds - overdrive = no conversation or hearing the radio. I've looked into the spray on stuff, I'm a little worried I'd screw it up. Isn't there a roll on product that's similar?
Another question, I was planning on using undercoating on the bottom of the floorboards for more sound deadening. I've been scrubbing away for a couple days prepping the area. I've heard good and bad about undercoating, any opinions on putting it on the floorboards? I don't plan on putting it on the frame.
Old Sep 2, 2009 | 07:44 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
this stuff is not for heat. it is for sound only. the thick tary stuff absorbs sound and vibration and needs to be agaisnt the surface you are wanting to kill sound from. i am guessing the shiny smooth stuff helps reflect the sound from the speakers back into the car.
Old Sep 2, 2009 | 07:47 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i was planning on using undercoating and was advised not to because some of it tends to bleed when it gets wet and will have residue that will run where you dont want it. just double or even triple the e-dead or dynamat on the interior.
Old Sep 2, 2009 | 09:28 PM
forvicjr's Avatar
forvicjr
I used reflectics, it was the way to go, two days ago on here...
Old Sep 3, 2009 | 12:00 AM
wiseman79's Avatar
wiseman79
Well I ended up going with this- Clicky. It's a 100 sq feet and 80mil thick and comes with some prep cleaner and roller. I'll update when I receive it. I won't know how effective it is for a while since I just pulled the car apart for an early start on winter projects, sound proofing being one of them.
Old Sep 3, 2009 | 12:01 AM
Blain's Avatar
Blain
Just bought a 50 sq ft roll of Fat Mat off an EBay store for $129
Its about 1/8" of butyl rubber and the aluminum face. Sticks well. Won't know how well it works until project is finished. Let you know about 2012!
Blain
Old Sep 3, 2009 | 08:55 AM
houstonvett
I have done the reflectrix route using the 3M 8001 glue on my 78. I will use the Dynamat spray on next time. I don't think it will be that hard to spray on. Wiseman79 Eastwood makes a good undercoating remover. Spray it on and it breaks down the glue thats in the undercoating, works very well. These are some of the pics of the reflectrix job, houstonvett
Old Sep 3, 2009 | 09:44 AM
Droptop-Rob's Avatar
Droptop-Rob
Hustonvette,
Did you like the 3M 8001 glue? did it hold well? Thanks
rob
Old Sep 3, 2009 | 11:06 AM
houstonvett
Originally Posted by Droptop-Rob
Hustonvette,
rob
Yes, the 3M 8001 is the glue to use. Bonds very quickly which is important around radiused pieces like the wheelwheels. Once it cures it doesn't move, super strong, I wouldn't use anything else Droptop_Rob. 3M 8001 costs a little more but well worth spending the extra money for the good stuff, houstonvett
Old Sep 3, 2009 | 12:54 PM
FB007's Avatar
FB007
That is a vapor barrier on a home. NOT the same thing.
Old Sep 3, 2009 | 06:21 PM
wiseman79's Avatar
wiseman79
Houstonvett that looks awesome, I hope for nearly that thorough of a job. Did you just do the interior or did you do any in the trans tunnel or anywhere else?
Old Sep 3, 2009 | 10:18 PM
houstonvett
Wiseman79 I will be spraying the Dynamat on the bottom of the car. I will let it cure for about a week and then go back and undercoat the bottom of the car. With the same gun that I shoot the Dynamat with, I can shoot the top line undercoating. The undercoating that comes out of a spray can doesn't perform as well as the spray on type. The Dynamat is in a water soluble form, so just in case I will make sure the Dynamat never gets exposed to water using the undercoating for a sealant, houstonvett
Old Sep 3, 2009 | 10:48 PM
wiseman79's Avatar
wiseman79
Thanks for the info. For all interested in the subject I found this website that has some great info- http://www.sounddeadenershowdown.com/
eastltd's Avatar
eastltd
I paid just under $200 to get two fifty foot rolls of FatMat delevered to Canada. I think in the US you can pick it up for about $150.
The stuff went in easy and seems to be doing a good job.
The car is a quiet as the pipes will allow
To Knock off dynamat opinion?
