76 Vette Dead, No Power
I was driving my 76 corvette, and pulled up to an intersection, as I was going throught the intersection, everything, like some one turned off a light switch, went dead. I coasted throught the intersection, and tried to restart the car, nothing. I noticed upon inspection under the hood that the pig tail that connects to the top of the Alternator, had cam loose and the red wire was broke out of the back of the plastic conector. I thought this was the problem...
So here is a list of what I have done, all from suggestions of far better electrical guys than myself:
1. Replaced the Pigtail at the alt, and tested to make sure I had connectivity
2. Tested Starter at local autozone, tested fine
3. Replaced and tested both fusible links at starter, both are good
4. Tested both pos and neg batterycables, both tested fine
5. Checked every fuse in the fuse block below stering wheel, all fuses are good
6. Tested fusible link at dist block below mater cylinder, it also tested fine.
7. Tested battery, and it as well tested fine.
I dont know a lot about electrical, and only have basic knowledge of diagonosing such things, but I will put the starter back on in the morning (06 Sep 09) and hook the battery back up, for another go at testing everything, but as of right now I still have absolutly no power to the vehicle, none the lights dont work, it won't crank, it essentially is a giant paper weight, and I am starting to get frustrated.
VR
JR
With the VOM I would start at the battery and see where you lose power. Check the voltage to ground from the battery, if you have voltage there, check the other end of the positive battery cable which if I remember right is the starter. If you don't have voltage from the starter to ground then there is a problem with either the cable or ground. I would just go through the car like that until you find it. Once you find where you no longer have voltage to ground use a jumper wire to check for voltage to a known ground. You might have to use a piece of wire as a jumper since the battery is so far away from the other electrical connections. If you have voltage using the jumper then you have a ground problem.
The battery location and the fiberglass body can make this harder than other cars.
I would check for voltage instead of checking for continuity if the wire or the part is connected at both ends. You can get continuity from somewhere else in the circuit. The ground wire from the battery to the frame can also test ok with continuity but a bad or dirty connection can prevent the current from traveling through the connection.
Good luck and keep us updated.
Try this:
Attach volt meter to fuseable link and a good ground
If you get 12v turn on head lights.
If voltage goes away fuseable link is passing a small amount of voltage but will not carry a load.
This is a first step. Post results and the guys will suggest options.
JR
