Hydroboost and MC upgrades?
Old Sep 7, 2009 | 02:43 AM
carbster09's Avatar
carbster09
Default Hydroboost and MC upgrades?
Hey guys,
I want to order a complete hydroboost kit; but Hydratech's website does not have a link for a C3. And there is not a phone number on the site.
Does anyone have a number for them? Does VB and P sell these? Their site is down too!
I would not mind having a better MC; like a Wilwood if it helps. Any opinions? I do want to fit an adjustable brake bias vlv(wilwood unit); where should this go and should I have the check vlv (the thing that GM calls a proportioning vlv) in the system removed?
Any pics and comments would really help. A shop is doing this for me as I am out of town for a while ....
Which Wilwood MC is correct for my application? I have seen a few pics on here with them fitted. They look nice.
carbster
Old Sep 7, 2009 | 03:06 AM
eagle275's Avatar
eagle275
Is this what you are talking about? I got this from VB&P, and believe me, you will stop! LOL!
http://www.vbandp.com/Our%20Catalog/source/page_49.htm
Old Sep 7, 2009 | 05:39 AM
carbster09's Avatar
carbster09
Default that's it!
Good price. I take it you can recommend the kit?
Anyone with info on the Wilwood MC and brake bias vlv?
carbster
Old Sep 7, 2009 | 08:04 AM
Binnie77's Avatar
Binnie77
Here is my documented install. I have the Wilwood part number listed there as well.
Hydroboost Install in C3
Old Sep 7, 2009 | 01:48 PM
eagle275's Avatar
eagle275
Default I do recommend it....
It's great!
Old Sep 8, 2009 | 12:49 AM
carbster09's Avatar
carbster09
Great write up thanks!!
Old Sep 8, 2009 | 07:49 AM
flynhi's Avatar
flynhi
Be wary of installing an adjustable brake proportioning valve and altering the front/rear bias unless you REALLY know what you're doing.
Old Sep 8, 2009 | 09:26 AM
70 LS1's Avatar
70 LS1
carbster
The C3 came front biased from the factory and the brake bias valves you can buy only reduce the amount of rear braking. This shifts the bias even more to the front. So unless you have aftermarket calipers, I wouldn't bother with a bias valve.
Here is some interesting reading on brake bias.
http://www.stoptech.com/tech_info/wp...formance.shtml
Old Sep 8, 2009 | 11:05 AM
carbster09's Avatar
carbster09
Default Brake bias
I have Corvette Engineering's Wilwood calipers; dyanlites. I run 235/50/16's up front and 255/50/16's out back. I have had the rears lock up before the fronts. ...... .... so unless i am wrong there is already a "brake bias" issue for me to sort out? What do you reckon?
With the size of the tires we run, the grip with modern rubber and better brakes ... these cars aren't exactly stock any longer.
carbster
Old Sep 8, 2009 | 11:12 AM
70 LS1's Avatar
70 LS1
I agree, you have an issue. Sounds like an adjustable proportioning valve would be of some benefit to you.
Old Sep 8, 2009 | 01:23 PM
68 NJConv 454's Avatar
68 NJConv 454
I can also recommend the hydroboost setup.
I bought my kit a few years ago directly from Hydratech.
Consider upgrading your power steering pump.
I have a stock vette saginaw pump and sometimes it struggles especially when turning at slow speeds with or without the brake pedal engaged. Depending on your engine & exhaust setup you want to keep the power steering fluid as cool as possible. I ran my lines as far away from the headers as possible but I made custom SS teflon lines. Rubber will not do on the pressure side in this setup.
If you're going racing you would also benefit from a remote resolvoir for your power steering pump.
I also run the Red Line hi temp power steering racing fluid.
Binnie, what is the size difference b/w the Wilwood MC and a stock vette MC? Is the Wilwood that much smaller?
Old Sep 8, 2009 | 01:31 PM
68 NJConv 454
Found some pics.
Old Sep 8, 2009 | 06:02 PM
eagle275's Avatar
eagle275
Default 68 NJConv 454
what power steering pump would be a good upgrade? Open to suggestions from everyone also. Thanks!
Old Sep 8, 2009 | 06:52 PM
68 NJConv 454
Originally Posted by eagle275
whay power steering pump would be a good upgrade? Open to suggestions from everyone also. Thanks!
There are some new cars that come from the factory with a decent LS power steering pump and remote plastic reservoir that you could probably snag at a salvage yard. Thought I remember seeing this on Power Block recently or one of those other shows. I'm sure someone out there has mounting braket adapters already.
I think these krc pumps would be ideal with their remote reservoir that can be mounted just about anywhere away from the heat. Once I'm able to save up the funds I'm going with one of their kits.
http://www.krcpower.com/products.html
There are many manufacturers of aftermarket power steering pumps I just like the KRC ones.
Also, when i say race i mean autox, obviously not 1/4 as I doubt you'll be installing anything but manual brakes on a 1/4 dedicated track car.
Old Sep 8, 2009 | 11:24 PM
eagle275's Avatar
eagle275
Default Thanks!
CRC is another.
Old Sep 8, 2009 | 11:41 PM
Ray Y's Avatar
Ray Y
Default alternate consideration
I'm not using this ABS system (yet) but I know some guys who are very pleased with it.
http://www.abspowerbrake.com/electrichppage.html
Old Sep 9, 2009 | 02:54 PM
Binnie77's Avatar
Binnie77
This Wilwood master cylinder is a direct replacement for the stock one. The bore is 1 1/8, reservoir capacity is almost identical and the brake line geometry is the same. A thing about it is that it is less than half the weight of the OEM and is a pleasure to bleed.
To Hydroboost and MC upgrades?
Old Sep 9, 2009 | 07:47 PM
eagle275's Avatar
eagle275
Default carbster... found this on this site
http://web.archive.org/web/200310040...=190&TopicID=3
Old Sep 9, 2009 | 10:43 PM
shashi27's Avatar
shashi27
carbster
Believe the Wilwood MC is 260-8556P (1.12" bore)
I have the MC and am waiting on the kit. Hope to have step by step pics when it comes.
Old Sep 10, 2009 | 10:30 PM
68 NJConv 454
Interesting. So no power steering pump to power this puppy, just the electric accumulator. Takes up less room under the hood too.
Very interesting. Anyone know the price?
