Under Hood Light Question
Old Sep 7, 2009 | 12:51 PM
uncle phil's Avatar
uncle phil
Default Under Hood Light Question
Got a crazy question here:
I have a 79 Vette. The under hood light is laying over to the side in the engine compartment.
My question is......where is this light supposed to mount ??
Any info is much appreciated !
Phil
Old Sep 7, 2009 | 01:02 PM
Ganey's Avatar
Ganey
Attaches to hood above the bracket that holds hood open.
Old Sep 7, 2009 | 01:08 PM
BHRIG's Avatar
BHRIG
Phil
The underhood light on the 77 attaches to the hood near the driver's side hood hinge..
The years of the closing the hood had probably loosened the screws and they fell out or enlarged the attaching holes..
You can use s slightly larger screw but will have open the holes on the bracket slightly..
Good Luck
Old Sep 7, 2009 | 01:26 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Where is the is the on/off button ?.....
Old Sep 7, 2009 | 01:43 PM
Ganey's Avatar
Ganey
Lights w/ hood open. Grounds to support.
PS I added a disconnect to mine on + side.
Old Sep 7, 2009 | 03:48 PM
bluthundr's Avatar
bluthundr
It is controlled by a mercury switch
Old Sep 7, 2009 | 04:10 PM
...Roger...'s Avatar
...Roger...
Grounds to support.
Hmmm.... what the heck does the support ground to ?
One other note and nobody probably gives a hoot but the hood light has its very own fusible link.
Old Sep 7, 2009 | 05:01 PM
SIXFOOTER's Avatar
SIXFOOTER
mine had a ground wire that went into the harness, mercury in the base of the socket turned it on, and yes it is on its own fuse link
Old Sep 7, 2009 | 09:34 PM
uncle phil's Avatar
uncle phil
Thanks guys....sounds like an easy fix !!
Phil
Old Sep 7, 2009 | 09:42 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
OOOOOOOOhhhhhhh....A mercury switch in the base of the socket hu?....I thought it was the plunger at the top of the firewall on the passenger side......Another mystery revealed !.....
Old Sep 7, 2009 | 09:47 PM
...Roger...
Thats the hood switch for the alarm.
Old Sep 8, 2009 | 07:35 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Funny, I thought the plunger was for both the alarm and the light.I have it disconnected and I took the light bulb out.....The bulb is back in now and I almost got blinded in the process........Mercury switch in the socket......I would not have guessed that in a million years!
To Under Hood Light Question
