Transmission Kick Down Bracket Question
Old Sep 7, 2009 | 09:38 PM
uncle phil's Avatar
uncle phil
Default Transmission Kick Down Bracket Question
I have this 79 Vette, and the previous owner installed a Edelbrock Performer Carb and intake. The transmission kick down cable is not connected because there is no bracket. The previous owner said he left the cable loose so he could manually shift it. It has a AT trans.
My question is, where can I find the correct (or one that will fit) trans kick down cable bracket ?
I like being able to punch the accelerator to hit passing gear. Is there really any good reason not to have the kick down connected ???
Appreciate all your feedback and advice !!!
Phil
Old Sep 7, 2009 | 10:03 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i am sure edelbrock sells all the bracketry that you could need, also Lokar
i cant imagine why some one would not have this connected.....sounds like a bubba move
Old Sep 7, 2009 | 10:21 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Exactly what I thought when I read it...You have to be a total moron , not to connect that .
Old Sep 7, 2009 | 10:52 PM
Jack Wood's Avatar
Jack Wood
Default Edelbrock and Holley have the kickdown brackets.
Just be sure to mention it's for a TH-350 or whatever tranny is in the car.
Old Sep 8, 2009 | 08:18 AM
uncle phil's Avatar
uncle phil
Thanks for all the info. I never figured out either why anyone would not want that connected. Now that I know where to find the bracket, I'll be connected in the next few days for sure!
Thanks !
Old Sep 8, 2009 | 09:34 AM
chazcax's Avatar
chazcax
Default I Have an Edelbrock carb with a TH350
It has a kick down connection on the same bracket that the throttle cable connects to. It is at the bottom of this bracket. I can take a pickture of it tonight and send it to you if this would help.
Charles
Old Sep 8, 2009 | 11:19 AM
uncle phil's Avatar
uncle phil
Charles,
A pic would be great ! I'm not really sure (without a pic) where it needs to connect on the carburetor linkage. A pic would be awesome...thanks !
Phil
Old Sep 8, 2009 | 05:17 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Originally Posted by uncle phil
Charles,
Phil
It goes on the same mech that the accelerator cable does..but on the lower prong...Pull it all the way forward an slip it over the "ball" and pull it back.Above the spring and below the accelerator cable...That's all....PM me your e-mail and I'll get a picture to you asap.
Old Sep 8, 2009 | 07:16 PM
mbarney's Avatar
mbarney
On my 80 its a seperate bracket that bolts to the rear two intake bolts. There is no place to mount it on the throtle bracket. If you have a late 79 it might be the same.
Mike
Old Sep 8, 2009 | 07:55 PM
uncle phil's Avatar
uncle phil
I got my kick down bracket today, and got it installed. The transmission isn't shifting down when I punch the accelerator, so I'm sure I just need to adjust the linkage where it has less travel. That seems like that should work.
Old Sep 9, 2009 | 10:01 AM
bobs77vet's Avatar
bobs77vet
i dont know about that......my guess is that the cable has become disengaged in the transmission. when you manually pull on the cable can you feel it pull something? you may just have to loosen the one bolt on the attachment bracket on the trans and slip the cable back on. if you do this use blue RTV sealent on the bracket when you put it back in .....i have been using a 700r4 for so long i have forgotten all i use to know about the th350.....but isnt there some vacuum modulator on the trans also?? i wonder if that got diconnected and not hooked up again in the swap
Old Sep 9, 2009 | 02:16 PM
uncle phil's Avatar
uncle phil
I messed around with the linkage, and now it is really kickin' butt!! I'm so glad I hooked this kick down back up. I love the way it slams you back in the seat when you step on it. I knew there was something missing.
Thanks for all the info you guys gave me.
Phil
Old Sep 9, 2009 | 05:13 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Phil
Now put a B&M shift kit in the tranny...You'll REALLY love it !....
Old Sep 9, 2009 | 06:35 PM
uncle phil's Avatar
uncle phil
It already has one in it. I guess I am set : )
Old Sep 9, 2009 | 07:00 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
I kinda thought so...Yee haw !..
Old May 13, 2013 | 01:26 AM
Danny Clsyton's Avatar
Danny Clsyton
8th Gear
I just installed Vortec heads and manifold on my '79. The kickdown bracket mounts on the last two bolts of the intake. The Vortec manifold has different pattern. Bracket will not work. Who offers a bracket for Vortec?
Old May 13, 2013 | 11:52 AM
Shark Racer's Avatar
Shark Racer
As mentioned above, Lokar sells universal brackets that you can set up for kickdowns, they'll also have provisions for a throttle return spring. Pretty stuff too.
Old May 13, 2013 | 11:59 AM
Jig A Low's Avatar
Jig A Low
make sure you study up on how to adjust the cable, if you get it wrong you can damage the transmission. and yes, there is a technique to it.
To Transmission Kick Down Bracket Question
