Front spring RE-alignment help
Old Sep 8, 2009 | 12:08 PM
Dick72LT1's Avatar
Dick72LT1
Default Front spring RE-alignment help
Hi guys,
I installed re-built A-arms and new front springs awhile ago and I just got around to installing the shocks. First one was a piece of cake; second one is a problem. The spring will not allow the shock to slip into the top hole. The spring is not aligned properly. I can feel that the bottom is about 1/2" from the stop so I'm assuming that top is not seated properly. I can see that the spacing around the spring is unequal.
Here's my question: Can I compress the spring enough with a spring compressor to re-align it without removing the spindle. I'm trying to avoid total disassembly if possible. My first attempt with an internal compressor was unsuccessful. I'd like some advice before I take it all apart.
Thanks,
Dick
Old Sep 8, 2009 | 12:13 PM
Bowerss2's Avatar
Bowerss2
you should be able to, i made my own spring compressor out of a piece of bent acme threaded rod, and some welded plates. The slight bend in it helps a lot for clearence. Using flat plates (with some welded on bar stock so they dont slip) to compress the spring helps a lot as opposed to the hooks because you can get a lot more travel out of the compressor.
Old Sep 8, 2009 | 01:25 PM
noonie's Avatar
noonie
You have the front jacked up and the lower a arm extended to it's lowest position I hope.
Should be no problem with this type compressor.
To Front spring RE-alignment help
