700r4 questions
Old Sep 11, 2009 | 01:45 PM
imdawrlus's Avatar
imdawrlus
Default 700r4 questions
not to beat a dead horse but i've tried a quick search and didnt come up with too much. 2 years ago i installed an 82 700r4 in my 79. just recently reverse quit working so its time to swap it out. the transmission i installed was free so thats why it went in.
i've read that 88 up are the better 700's. what year did they become computer controled? i want to be able to run it with just a tv cable and whatever wiring for the lockup. so whats the last year before they became electronic?
and also are transmissions that were mated to 305 engines the same as ones that came from a 350?
Old Sep 11, 2009 | 02:38 PM
Iskenderian's Avatar
Iskenderian
all 700R4's are not computer controlled (if wrong someone correct me) 1993 is when vettes got the 4L60E (computer controlled 700R4) transmission is the same except for the 60E has no TV cable, its all computer. BTO has good crossmembers for R4 swaps. thats what I use in my LT1/4L60E swap.
as far as how much abuse they can take, ive heard the later ones (up to 1992) are better, but Ive got nothin' to back that up.
-Bob
Old Sep 11, 2009 | 02:43 PM
jackson's Avatar
jackson
I'm Not a go-to guy on transmissions. I understand later ones have stronger input shaft. I got a 700r4 from a 1992 rear drive caddy w/OE chevy v8 ... it is Not computer controlled. Depending on make/model application ... last year was 92 & 93. I haven't installed this one so I cannot comment on its fit/function yet ... but it's quite clear it'll fit chevy sb/BB block. Nice clean car was hit hard in driver door. I got driveshaft too; may need it to cut/mod. Suggest you look for 92 full size 4-door gm car (granny car) with OE chevy v8 ... such car probably been easier on trans than truck, camaro etc. If vehicle hit in front/rear ... check case, mounts etc for cracks. Retired Impala-Caprice tough to get around here; real popular w/ thugs.
Old Sep 11, 2009 | 04:42 PM
hugie82's Avatar
hugie82
I was told 88 and up are stronger with a larger 30 spline shaft compare to the 27 spline. 93 was the first year it became all electronic.
Old Sep 12, 2009 | 10:49 PM
imdawrlus's Avatar
imdawrlus
i found a transmission on craigslist from a smashed up 89 camaro. 150 bucks and it looks really clean on the outside and the fluid dosent look bad either. the guy i bought it from said it worked fine. i'd rather take someones word for it then buy a muddy peice of trash from a junkyard. the price was deffinately right and he seemed trustworthy. looks like i'm gonna be busy for the next few days
Old Sep 13, 2009 | 06:35 AM
rpoL98's Avatar
rpoL98
before you put in the used trans, consider doing the following basic stuff:
replace front seal. the one that mates with the torque converter.
install high-perf governor (will affect shift points) from vette or IROC.
install your choice of shift kit.
of course, replace filter and use torque wrench when replacing pan gasket.
Old Sep 13, 2009 | 11:52 AM
imdawrlus's Avatar
imdawrlus
i was thinking of doing the front seal, theres some oil residue on the inside of the bellhousing and i havent figured out where its from. it could be a rear main on the engine or it also could be from leaky valve covers or intake gasket dripping down, or the seal on the tranny.
is doing the front seal just like doing any other type of lip seal?
Old Sep 13, 2009 | 12:48 PM
Alwyn678's Avatar
Alwyn678
Exactly what I heard when I was researching one before I swithched to a 700R4
Old Sep 13, 2009 | 01:55 PM
64_365's Avatar
64_365
So...how do you guys that have performed this swap like your 700-R4s?
Old Sep 13, 2009 | 02:42 PM
Kellys~hotrods's Avatar
Kellys~hotrods
I swapped a TH 350 for a TCI "Street Fighter" 700 R-4 and changed the gears to 3.73:1 in the rear end. I love the swap. Lower gears mean a much harder launch, while the O.D. means I can cruise on the highway at comfortable RPM's. The swap was done in my 1978 stepside chevy pickup. I did have to move the transmission cross member and I ordered a slightly shorter (Aluminum) driveline because of the longer overall trans length.
For the cable controlled 700 R-4's look for a large K on the case, this will indicate a stronger casting.
Old Sep 13, 2009 | 07:59 PM
rpoL98's Avatar
rpoL98
when replacing the front seal on the trans, using one of those curved seal pullers, be very careful that the tip of the hook only engages the steel part of the seal, and not the bushing that's right behind it.
otherwise you might accidentally carve a huge gouge in the bushing.
other than that, it's pretty straight forward, should pop right out. there might be a seal retainer (circular type of clip thing), that's good insurance. once upon a time, these seals used to come out for whatever reason, probably the earlier versions.
Old Sep 13, 2009 | 08:10 PM
piperkansas's Avatar
piperkansas
I've heard from a reliable source that the stronger 700R4's all have the large cam shaped casting line on the RH side of the case. It's pretty easy to see when the trans is out on the floor but can be a little difficult to pick out if the trans is in the car and dirty.
Old Sep 14, 2009 | 11:14 AM
imdawrlus's Avatar
imdawrlus
exactly. it looks like a big rainbow shaped swoop in the casting that comes up and goes right through the middle of the top fitting for the cooling line.
the 700r4 swap is well worth the effort, highly recommended
Old Sep 15, 2009 | 02:12 AM
imdawrlus's Avatar
imdawrlus
put a new input shaft seal in the transmission tonight...anyone else not like the look of these seal retainers? they look pretty flimsy. do they ever fall off?
To 700r4 questions
