F---ed myself somehow.
he picture I'm including is of everything installed but before I rigged the vacuum system up. I've used my extensive Microsoft paint skills to highlight all or most of the lines that require vacuum pressure.
Before the switch my PCV valve was hooked to a port at the rear of carb but ON the spacer. When I switched manifolds I no longer needed the spacer. Currently its hooked to small vacuum manifold which also services the lines for my headlights/wipers. I'm THINKING this is where my problem lies but I'm not 100% certain how to fix it. The speed shop guys told me a should of had a port on my carb in the same position as it was on the spacer.
Ideas?
"I myself get rid of the carbs, vacuum master cylinder and use a Hydroboost for the brakes"
but if you could provide links to what you consider GOOD reading material I would appreciate it greatly. As for electronic motors, I've heard good things but once again I'm no mechanic. I'll begin googling the terminology I haven't understood now. Thanks for your advice.
Blue line in your pic is power brakes; nothing should be sharing this line with the booster. It usually runs from the base of the carb.
Green line should be the vacuum advance to the distributor.
Red line from the PCV should route to the base of the carb, not the headlight supply.
Caution: Your rubber fuel lines to the carb are dangerous. A potential fire hazard.
Run your brake booster to another port on the manifold by itself or tee it into your purple on the manifold. Really all the rest of the of the vacuum lines can go to any port on the manifold, that is available like the one mentioned above.
Distributer is good.
To test for leaks, you can temporarily disconnect and plug all except the pcv and the distributer.
Rick B.
Set your timing to give you about 35 degrees of advance at around 3000 or 3500 rpm. Then plumb the vacuum advance to run off the small manifold vacuum port. This should put your timing at idle up around 30 degrees which will help your idle quality significantly. You'll probably notice your idle speed will be higher which you can then adjust using the idle speed screw. Also, make sure your idle mixture screws are at the factory setting which should be 1 1/2 turns out.
Reattach the blue line from the brake booster and see if there is any change in the idle. Then put the car in drive and fine tune your idle speed using the screw.
Is the carb new? Has it been thoroughly cleaned and properly reassembled if it wasn't new? What is your manifold pressure at idle? Do you have around 6 to 8 psi of fuel pressure?
From the bottom up:
yellow94coupe
"Is the carb new? Has it been thoroughly cleaned and properly reassembled if it wasn't new? What is your manifold pressure at idle? Do you have around 6 to 8 psi of fuel pressure?"
I'm not sure about the condition of the carb or how to check the manifold or fuel pressure but I'll get back to you as soon as I can. Most of this will have to wait until my day off (tomorrow). My only question is whether or not you're suggesting the brake booster line be attached at the manifold instead of the carb to make room for the PCV's line. I only have 1 port on the carb of this diameter that I can find. My other vacuum port (smaller) is hooked to my distributor. Thank you for taking the time to respond.
72LS1Vette
"Where was your brake booster hose connected previously? Usually the booster hose is run from a fitting on the manifold. That hole to the right rear of the carb can be drilled out for a fitting. Another thing you may have done wrong is plug the distributer in a tooth off."
Brake booster is in the same place it was originally... on my only large diameter vacuum port from the carb. Are you saying I can potentially have another port added to my carb of this diameter? I'm not sure what you mean by your last sentence.
However thank you for responding.noonie
Definitely something I will be trying. Thank you for the suggestions.
Easy Mike
"Red line from the PCV should route to the base of the carb, not the headlight supply.
Caution: Your rubber fuel lines to the carb are dangerous. A potential fire hazard."
In the pic my PCV is resting off to the side. I mentioned I hadn't hooked all the vacuum stuff up yet. I took the pic while pulling my hair out wondering why it all couldn't go back in the same way it came out. lol. I've seen metal fuel lines but haven't invested due to my towering ignorance. Any advice in this area? Thanks for your time and response.
Fishndude
I apologize for not communicating myself effectively. The picture is of the system before I rigged the vacuum system. That port is now holding a small plug with 3 vacuum ports on it; my PVC valve, headlights and wipers. Thanks for your response all the same.
Take a look around the base of the carb, sometimes there are other ports hiding down there. If you don't find any disconenct that brake booster line and plug in the PCV. I don't think you need that brake booster vacuum line to idle or even drive and brake (you wil lose your power brakes, however). If your idle smoothes out and comes up you have identified the problem. If not, move to some of the other more complicated suggestions. Carb cleaner is a great trick, when it finds the leak rpm should jump noticeably. Last time i had a leak, I had a vacuum plug on my carb dissintegrate and the end fell off... harder to see because it looked like the cap was on there but $2 fix.
Plug up all those holes in the manifold too - what are those holes up by the water neck? Heck, while the car is running stick your finger in them and see if the idle comes up. They are big enough that you can probably hear the air whistling in them. Another trick you might try is to start the engine and cup your hands over the top of the carb to cut off the air. The car should die because you've choked off the air. If it does not you know you have a vacuum leak because it's running on air coming in from somewhere else.
Lastly, you used new intake manifold gaskets and remembered to put the gasket back between the carb and manifold right?
This is the tired engine compartment i inherited:
First thing I changed was fuel lines:
I bought this:
http://www.summitracing.com/parts/RU...0/?image=large
but you have to make sure it is for your carb. They are carb specific. If you are looking at my vacuum lines note that I do NOT have power brakes.
many holly carbs only have 1 large vacuum port on the back for the power brakes.
the street avenger series i believe has two.
you may have not gotten the new intake manifold sealed properly.
and be sure to check to see if the vacuum advance cannister is holding vacuum that could have a bad diaphram
#1--It appears from the pic you have an open vacuum port at the rr of the carb.
#2-- You could run your PVC to the blue port on the carb( i believe that is the pvc port),leave the green hose going to the dist. , and block all other vac hoses until you get it running right in the driveway.
To respond to some info already given-
1: You don't need vacuum advance connected for the motor to run, plug it to rule that out.
2: Vacuum leaks usually raise idle.
In the beginning you'll make lotsa mistakes..I know I did (still do).
Buy yourself a couple of good books:
- Haynes Corvette manual (pretty much every auto store)
- Books dealing with building/rebuilding Small Block Chevy
- Books by David Vizard
Distributor 180 degrees off
Plug wires in the wrong order
Vacuum lines on the wrong ports
using a hammer when you need a screw driver
all of it.
