It's U joint time !!!
Old Feb 21, 2002 | 06:33 PM
Chris69's Avatar
Chris69
Default Re: It's U joint time !!! (silvervetteman)
SilverVetteMan.... Where did you get your Spicer's? Do you know if they had the solids?
Old Feb 21, 2002 | 07:11 PM
Ingar, Norway's Avatar
Ingar, Norway
>Still looks like their "replacement" joints have the side angle mounted fittings
Yes agree, but their document 3264a_spl.pdf shows installation pictures of a "conventional" joint with the center zerck
Old Feb 22, 2002 | 09:29 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I've had mine done but I haven't done them myself for lack of a press. One of the few things I haven't done. The guy I know at the local shop will r&r a pair of them for like $10 which is cheap enough to justify me not messing with them.
What centers the joint in the shaft? Seems like you could assemble the thing so it's all off center & kittywompus or something and have a nasty vibration as a result.
Dave
Old Feb 22, 2002 | 06:12 PM
Larry B.'s Avatar
Larry B.
I just got my Spicer U-joints. They are solid. $22.20 each from a local place called Advanced Driveline. They also have yokes and repair yokes. I'll be talking to them again about the yokes as there are several different ones. I know the repros show couple of different ones depending on years and trans type. But Advanced's list shows several different lengths also ! (Some just a few thousanths different and others close to an inch different) :confused:
[Modified by silvervetteman, 4:15 PM 2/22/2002]
Old Feb 22, 2002 | 06:16 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
But Advanced's list shows several different lengths also ! (just a few thousanths different) :confused:
Just a few thousanths different? I wonder if that has anything to do with my driveshaft vibration. The listed u-joints don't fitmy car. I have no idea if my driveshaft is correct (my engine & trans aren't, so why should the shaft be correct?). Hmmm...time to go shopping for new u-joints maybe.
Old Feb 22, 2002 | 06:38 PM
Larry B.'s Avatar
Larry B.
Default Re: It's U joint time !!! (ddecart)
Yeah!! They show Centerline to end of yokes....6.70, 7.23, 7.27, 6.74, 7.42, 6.57, 7.36, 6.59, . Plus alot of P/N's These take 3 different U-jount although most take the same one. :confused: :crazy: :crazy: Pretty strange huh! :eek:
[Modified by silvervetteman, 4:40 PM 2/22/2002]
