Distributor trouble?
Old Sep 12, 2009 | 09:51 PM
AWilson's Avatar
AWilson
Default Distributor trouble?
Ok, my engine is broken in. I can't run it more than 5-10 minutes without it getting hot and will have to work through that issue.
I have been following the timing sticky by Barry and I set my dwell right on 30 at idle. But when I rev it up it goes up to 36 or more. I am not really revving it very high either. According to the stick if this happens then my distributor main shaft has too much end play and needs to be repaired. Is this correct and do I seem to have this problem based on the changes in the dwell? Reason I say this is because the distributor was rebuilt by Lars and just now put into service.
Old Sep 12, 2009 | 11:21 PM
TimAT's Avatar
TimAT
Dwell is the length of time the points stay open. 30* is the center of the recommended range. They only way that will change is if the cam in the distributor is worn. And the number can't go up. If it's set at 30*, and the cam wears, (or the points wear) the dwell becomes less as the points close up.
You can "feel" your distributor and get a rough idea of any wear. Pull the cap, grab the rotor and pull straight up. The shaft should pull up a tiny amount- just enough to feel it. It's only .005, very small amount so if there's a big amount then you have a problem there. remember the distributor shaft will turn as it moves up too, so don't confuse the turn with the amount it moves up and down. If you're really worried, pull the distributor and measure the clearance between the top of the gear and the shim.
For that reason, I'm thinking you may have dwell and timing mixed up. At idle, your timing should be somewhere between 4 and 12*, with the advance coming in per the sticky. If you have the initial advance set at 30* that will be the cause of your heating problem. You need to check your initial timing and then add RPM to get to 36* @ 3000 RPM.
Old Sep 13, 2009 | 03:01 AM
AWilson's Avatar
AWilson
I appreciate the response but to me I don't see how I could be wrong. I have a digital timing lite. I set it to dwell. With the car running at idle it initially read 32. I put the 1/8 inch allen wrench through the little window on the cap and in the point adjustment screw. While watching the 32 I turned the screw until it said 30, which was only a slight adjustment of the screw. Then I revved up the engine and it went to 36-37. Released the throttle and it went back to 30. I did this 3 or 4 times. By then she was hot and I shut it down. So to me I was definitely watching dwell or the allen wrench wouldn't have had any effect on the initial 32 reading.
I can recheck tomorrow and I will check the play as you said.
I will also do the total timing. But if my distibutor is bad the timing will have to be redone. But so what, I need the experience and I would love to solve the heating problem that easily. BTW - Since break in, with vaccum advance line plugged, I set my initial timing to 4 per the book.
Old Sep 13, 2009 | 04:23 AM
Peterbuilt's Avatar
Peterbuilt
Check the gap between the bottom of the distributor and the gear, you should have less than .060 movement up and down. If more than that than you need to insert a shim.
Old Sep 13, 2009 | 10:24 AM
AWilson's Avatar
AWilson
Ok, I measured the amount that the distributor pulls up. I got .016 end play. 16 thousandths. That should be well within specs., shouldn't it? So what could be causing the dwell to move 6-7 degress higher between idle and higher RPM"S?
Old Sep 13, 2009 | 10:25 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The easiest and fastest way to know if you have an upper distributor bushing failure is to go to the dwell.
Awilson, you need to pull the distributor on this car and check the bushings as well as the condition of the main shaft.
Willcox
Old Sep 13, 2009 | 10:31 AM
AWilson's Avatar
AWilson
Willcox
What should the numbers be, or better yet do you guys do this? Your in Indiana so I can get it to you fast if you can turn around in a day, 2 max.
I just learned about spark scatter too. Maybe I have this. At high RPM, 3000 the timing mark jumps every couple of seconds then goes back. I thought this was normal.
Old Sep 13, 2009 | 01:52 PM
Dr.J's74's Avatar
Dr.J's74
if youre setting dwell you obviously have a points style ign. If youre hving issues w/ the dwell jumping around you most likely have a worn dist. shaft. now the easiest,best, and cheepest way to fix it would be to convet the distributer points with "Pertronics" style ign. You dont have to pull the stem or anything,just install according to directions in the box. you can get these units @ carquest or napa. They are much less persnickety than points especially if dist play is an issue. Plus you wont even have to swap youre cap or rotor, it all stays stock
Old Sep 14, 2009 | 08:22 PM
0Willcox Corvette
Former Vendor
AWilson,
I like to set the new points to 28 and used to 30. They can move open a little bit but nothing like you describe.
Replacement of the points kit with an HEI replacement would not be an option at this point. With the variance you have the upper bushing is either worn out or the point plate is worn out. One of the two can cause this problem but 99 percent of the time it is the upper bushing.
I don't know what type of H/P you have in your engine, but point bouce is not going to play a roll at 3000 RPM's with a good distributor. If you are running a H/P engine after a distributor re-build, I then would consider the HEI conversion kiits. If you are really pushing the h/p then do as I did on my 72 and go to the MSD or Excel Distributors. MSD makes a great tach drive distributor but you'll need the coil and the 6AL ignition box to run it.
IMHO,
Willcox
Old Sep 14, 2009 | 08:32 PM
midyearvette's Avatar
midyearvette
Willcox
Old Sep 19, 2009 | 05:04 PM
AWilson's Avatar
AWilson
Default New symptom
Ok, It appears that I did not have enough vacuum to allow me to be aware of all problems. Now that the vacuum is coming direct from the manifold and the distributor can is working I have a new symptom.
It is intermittent but I would say about 2/3 of the time the distributor is making a very fast clickety click sound. Not high pitched. When this happens the timing retards a good 4-6 degrees. The 1/3 of the time it is not doing it the timing snaps back. It only happens under about 950 rpm.
Old Sep 19, 2009 | 05:36 PM
...Roger...'s Avatar
...Roger...
Is the clickity click happening at idle ?
Old Sep 19, 2009 | 05:41 PM
AWilson's Avatar
AWilson
Yes it is basically at idle only, I put my ear to the distributor and it is quite obvious.
Old Sep 20, 2009 | 10:29 AM
Donald #31176's Avatar
Donald #31176
If you stick to the stock distributor then get it blueprinted to the specs for your engine. Have it taken apart, inspected for worn parts, lubed and the ignition map correctly curved to your engines spec. Correct the gear end play to .005-.010. Use HD points(BW112Hp, Accel 8104 kit) , a non emissions cap and rotor and the correct VAC for your engines vacuum characteristics. If you need a contact to do this work I can refer one to you.
The noise in your distributor is probably interference with the rotor tang & cap contacts. Check for deep marks on the cap contacts
To Distributor trouble?
