Dyno results
Old Feb 20, 2002 | 09:27 PM
Double Aught's Avatar
Double Aught
Default Dyno results
I got my Pace Car back from the Dyno Shop in Santee last week. I had the distributor worked along with the carb. They did the standard Dyno tune up: Plugs, wires, cap, rotor, HEI advance kit, and magnetic pickup. They also worked the secondaries, although I am not sure if they re-jetted them. The engine is making 160 lbs on a compression test. It is a stock L82, with 113k. The rear wheel hp was 220 @ 5200, with torque hitting 250# through the entire RPM range. The car has Heddman hedders, Hiflow cat and Flowmaster 2chamber mufflers. I figure the exhaust mods got me about 50hp over the factory rating at the flywheel. Not to shabby for a bone stock motor with high miles.
Old Feb 20, 2002 | 09:46 PM
Aaron-74's Avatar
Aaron-74
Default Re: Dyno results (sd pacecar)
Those are really nice numbers for such limited mods. How much did it cost??
Old Feb 20, 2002 | 10:00 PM
Double Aught
Default Re: Dyno results (Aaron-74)
It cost me 521.00. And I hope those figures represent rear wheel hp. They have the typical chassis dyno.
Old Feb 20, 2002 | 10:24 PM
Aaron-74's Avatar
Aaron-74
It probably is chasis. Unless you had the motor out. That's pretty good number for mostly a stock motor. Tuning is the most imortant factor of making power though. You can have all the go fast goodies in the world and make no power. I don't really know much about tuning though. Spark plugs, carb tuning, Ignition and all that. I'll leave that to my Auto Shop teacher. :smash:
To Dyno results
