linear actuator wiring
Old Sep 14, 2009 | 12:04 AM
KTKelly's Avatar
KTKelly
Default linear actuator wiring
Anyone using a linear actuator for lights or wiper door?
How did you wire it?
Use a separate switch for reversing power?
Old Sep 15, 2009 | 12:21 AM
Buddy1980's Avatar
Buddy1980
Default wiring
you use a double pole, double throw (dpdt) switch, the switch stays in the center position normally, push switch 1 way for out, push the other way for in. the switch has 6 terminals, 2 for power (12 volts), and the other 4 hook to the device for positive or negative feed. sorry i do not have a diagram, if you place all componets on the bench you can figure it out by trial and error. any electronic experts please chime in with diagram.
