What Oil for M21?
Old Feb 20, 2002 | 10:33 PM
Rob's 73's Avatar
Rob's 73
Default What Oil for M21?
Recommendations on brand and weight please?
Old Feb 20, 2002 | 10:35 PM
73Ken73's Avatar
73Ken73
Default Re: What Oil for M21? (Rob's 73)
90w gear oil any decent brand.
Old Feb 20, 2002 | 10:51 PM
redvetracr's Avatar
redvetracr
Rob,
Allow me to add my .02 cents worth to the above post "synthetic"
...redvetracr
Old Feb 20, 2002 | 11:23 PM
dman535's Avatar
dman535
Default Re: What Oil for M21? (redvetracr)
I run the Redline products in the manual tranny in my BMW. Top notch stuff.
http://www.redlineoil.com/products.htm
Old Feb 20, 2002 | 11:49 PM
73 LS-4's Avatar
73 LS-4
I've been running the Valvoline synthetic gear lube 75w90 in mine, seems to work just fine.
:cheers:
Pat Kunz
Old Feb 21, 2002 | 12:07 AM
Barry's70LT1's Avatar
Barry's70LT1
For many, many years, GM technicians here do not recommend using gear oil.
The reason I was told was that under cool/cold conditions, heavy Gear oil
does not lubricate properly. For years they recommended 30W engine oil.
Maybe something to do with the Canadian climate.
Now GM recommends "Synchromesh Transmission Fluid", PN 10953465.
This is a GM product.
States on the back of the bottle:
"Designed specially for use on GM manual transmissions. This product has excellent lubrication properties and does not break down. It withstands high temperatures and functions well in low temperatures. It is an amber colored light bodied base product that's a partially synthetic manual transmission fluid."
That's what I'm using in mine.
Barry
Old Feb 21, 2002 | 12:36 AM
Jim 77's Avatar
Jim 77
Default Re: What Oil for M21? (73 LS-4)
I'm using valvoline synthetic 75w-90. Wanted mobil one but couldn't get my hands on any that day. It made a noticable difference compared to the who know's what/how old stuff that was in there. I am very happy with it.
BTW its an M-20 (t-10)
Jim
Old Feb 21, 2002 | 02:16 AM
ScubaJKD's Avatar
ScubaJKD
Pretty hard to beat Redline. Call the tech line and tell them your driving parameters and the mileage on your tranny. They will recomend a specific wieght for your application.
:cheers:
Old Feb 21, 2002 | 08:32 AM
MassVette's Avatar
MassVette
Steer clear of rear end gear oil; most contain an additive for limited slip which will damage a manual trans. This was related to me by Richmond Gear when I bought the 6 speed. They recommended RedLine ONLY (no posi additives).
:yesnod: :chevy :chevy :yesnod:
Old Feb 21, 2002 | 08:57 AM
Rob's 73's Avatar
Rob's 73
Default Re: What Oil for M21? (MassVette)
Thanks for the replys
How much do I need?
Old Feb 21, 2002 | 09:40 AM
GaryS's Avatar
GaryS
Mobil 1 synthetic gear lube is the standard by which a lot of folks measure their gear lube. It is a great product and virtually all the auto parts stores carry it. I like the stuff enough to put it in all of my rear wheel drive cars. The same thing holds for its use in transmissions.
Gary
To What Oil for M21?
