While on the Caravan to the NCM My wipers died. The door opened, but would not close, then the Alternator died and so did the batttery. The Alternator was replaced as was the battery but eventually died again . The Alternator was replaced, along with the regulator, and battery. within 24 hrs a dead battery again. The Amp Meter on the center dash stayed in the middle and did not move. This is a new guage and it is possible that it has come disconected, but I believe it was working prior to all this fun stuff happening
When the car is turned off the wiper door closes, but the wipers do not work. Reading some of the literature, it may not be the wiper motor but a relay causing this problem.
So where do I start? The dash Wiring harness has been replaced fairly recently
By chance did you bump the wiper override **** under the dash? If it's on it breaks the ground for the wiper motor. The motor will draw down the battery if the override switch is turned on.
The purpose of the switch is to allow the motor to be stopped at the top of the travel to allow blade changes.
Remove the negative battery cable. Put one end of a multimeter probe on the removed cable and one end on the battery negative post. With the doors closed and all circuits in the off mode, you should not see more than a .02 amp draw. If a fully-charged battery is going flat (below 9v) in a 24-hour period, you are seeing an amp draw of around 3. This simple test will tell you if you have a circuit drawing. From there, you can start pulling fuses to isolate in what system you are drawing. If the draw is reasonable, then you know you are probably looking at a battery issue.
My battery drain problem (68) was solved by removing the wiper fuse. Of course that doesn't solve my wipers not working problem, but let's take care of one thing at a time.
I gave up trying to track down my battery drain problem and slapped on a cutoff switch. I also bought a spare battery and keep it charged in case I forget to cutoff the battery in the vette
