Choosing a Carb?
Old Sep 16, 2009 | 12:42 PM
shamby's Avatar
shamby
Default Choosing a Carb?
I'm having a hard time decided on which carb to get for my vette. The engine is a 355 with the Edelbrock performer rpm top end kit. Right now the car has an old Holley 750 that needs attention. I called summit and they suggest a 600, then I called Edelbrock and they suggested an 800 (wow big difference) Any suggestion I would greatly appreciate it.
Thanks Scott
Old Sep 16, 2009 | 01:06 PM
Ganey's Avatar
Ganey
Typical street 350 is fine w/ 600.
650 will do it for you. Edelbrock just has 2 sizes 600 & 800 so if they want to suggest more than 600 then 800.
This will help.
CARBS Tests TQ/HP
http://www.corvettefaq.com/c3/carbcomparo.htm
Old Sep 16, 2009 | 01:41 PM
shamby's Avatar
shamby
That's kinda what I thought. Thanks for the info.
Old Sep 16, 2009 | 02:15 PM
FRSTR90's Avatar
FRSTR90
I believe Edelbrock recommends the 1407 carb. My dad has the same package on his engine with the 1407 carb. The 750's seem to suit the engine well.. The edelbrock carb is not one that you will just be able to throw on out of the box. So personally, I would see if I could get the bugs worked out on holley before I'd consider an edelbrock carb.
Old Sep 16, 2009 | 02:29 PM
shamby's Avatar
shamby
I'll try to get the 750 working before spending the money but if it's to big of a PIA I'll get a 650 with electric choke. I just thought the 750was way to bid for the package.
Thanks for the post
Old Sep 16, 2009 | 02:48 PM
FRSTR90's Avatar
FRSTR90
I'll agree with you.. It does sound big, but when you starting turning this engine past 6500 it seems like the 750 does help. I had an edelbrock 600 for a little while on my mild L82 and it just felt like it was done after about 4000. I stuck an edelbrock 750 or 1407, and it seemed I lost a little low end, but I could definitely tell a much stronger pull at 3000. If I am not mistaken, the LT1's ran a 750 Vacuum sec DP. If you haven't noticed already, the Performer RPM manifold and the LT1 manifold are practically the same design. So in reality what you have is basically an LT1 with a better flowing manifold and bigger cam.
Old Sep 16, 2009 | 03:37 PM
MelWff's Avatar
MelWff
you dont mentiom, at least I didnt see it, if you are talking about a 750 double pumper or a vacuum secondary version. The old LT1, 70 to 72, had a 780 vacuum secondary.
Old Sep 16, 2009 | 03:56 PM
shamby's Avatar
shamby
Now I'm going to show my ignorance in carbs, but how can you tell. I'll look for some numbers on the carb
Old Sep 16, 2009 | 04:05 PM
MelWff's Avatar
MelWff
if there an accelerator pump attachd to both the primary, front, and secondary, rear, float bowls, it's a double pumper. if only the front has an accelerator pump and the rear has a piston like device on the passenger side it's a vacuum secondary. Look at the airhorn front for the list number of the carburetor
Old Sep 16, 2009 | 04:16 PM
shamby's Avatar
shamby
Here are the numbers on the carb 10569, 6931, 33, 8494. I'm almost positve it's vacuum.
Old Sep 16, 2009 | 05:47 PM
MelWff's Avatar
MelWff
it should be on the air horn/choke tower, a 4 digit number preceded by the word "List"
Old Sep 16, 2009 | 06:03 PM
shamby's Avatar
shamby
I actually found the invoive. In 1996 the carb was 178 bucks. Holley 3310 750 cfm vac/sec
Old Sep 16, 2009 | 06:47 PM
Ganey's Avatar
Ganey
A carb is a responsive device.
You could easily run 650-750 VS.
Old Sep 16, 2009 | 08:07 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I've got a Barry Grant Street Demon 650 on my '75.
Whatever you decide to go with just remember, know matter what the person over the phone tells you, the d*@m thing is not ready to bolt on and go out of the box.
I know this from experience.
Old Sep 16, 2009 | 10:08 PM
marz's Avatar
marz
Amen. I went through 3 jet sizes before getting where I needed to be on my BG 750 Speed Demon. But, the Holley and the Barry Grant are better carbs than the Edelbrock. I went through a couple of those and they were lacking low end response. I also stuck an Edelbrock AirGap RPM. Very responsive combo.
Old Sep 17, 2009 | 08:54 PM
stingraymyway
Got one more thing to add.
You may have to search for an air filter unit that'll fit/clear. My stock air filter base wouldn't fit down on the BG carb. The chrome ignition shield hit it. Had no problem with the Q-jet and the shield. Just a slight difference in position and....... think I found one that'll work.... I hope.
Old Sep 18, 2009 | 10:49 AM
mr.beachcomber's Avatar
mr.beachcomber
Originally Posted by shamby
I'll try to get the 750 working before spending the money but if it's to big of a PIA I'll get a 650 with electric choke...
Rebuilding your 750 isn't that difficult as long as you don't try to rush the job. I only use genuine Holley rebuild kits as other kits just aren't worth the money nor the time and effort to rebuild your "rebuilt" carburetor.
I've found that the Holley Technical Library to be a great source of information and recommend it highly.
I use the carburetor cleaner and dipping basket from NAPA on all my Holley carbs. The stuff works well and cleans up with water; however, you may already have a preferred cleaning solution.
Good luck with the rebuild!
To Choosing a Carb?
Old Sep 18, 2009 | 12:07 PM
1971 LS-5's Avatar
1971 LS-5
Mr. Beachcomber is right. Throw a HOLLEY rebuild kit at your 750. Basically you'll want to replace the gaskets and the needle and seat assemblies. I find the carb dips to be overkill unless your carb is really grungy and they are hard on plastic parts. Since your carb is a running carb all you probably need is a couple pans of kerosene, a can of carb cleaner and some compressed air. Cleanliness is the key! 750 cfm is fine for your motor. Set the floats right, get it jetted correctly, and set your idle mixture screws with a vacuum gage and you'll be good to go. If you feel you need more tune ability put a 4150 metering block kit on the secondary side.
Old Sep 18, 2009 | 10:27 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
You have the best carb for your application....and it's easy to rebuild and tune!
Old Sep 19, 2009 | 09:09 AM
marshrat99's Avatar
marshrat99
670 Holley Street Avenger here without issues for years except for those darn plastic sight windows which had to go after only a few weeks.
