73 Frame Replacement
Old Sep 16, 2009 | 06:05 PM
jayshe9999's Avatar
jayshe9999
6th Gear
Default 73 Frame Replacement
Can I replace a 1973 frame with a 1975 or 1976 without too much work?
Is there any books that give instructions?
My frame is rusted on the frame rails, differential crossmember and the driver side kickup.
Old Sep 16, 2009 | 06:31 PM
Artsvette73's Avatar
Artsvette73
It can be done but you will have to graft the rear frame rails and rear crossmember. The cut I made was stepped not straight. No book just measure twice and cut once
Old Sep 16, 2009 | 06:57 PM
crf311's Avatar
crf311
Best to get a 73 frame. 73 was the only year with rubber front bumper with chrome rear bumpers.
Old Sep 16, 2009 | 07:07 PM
stpman's Avatar
stpman
The 74 frame is similar but still requires work
Old Sep 16, 2009 | 09:16 PM
72LS1Vette's Avatar
72LS1Vette
But not nearly as much as a 75-76 frame.
Rick B.
Old Sep 17, 2009 | 01:31 AM
Buddy1980's Avatar
Buddy1980
Default 73 frame
I have a nice solid 75 frame if you are interested, pictures and ad are in c-3 and c-3 parts for sale. Can be used with little mods. you do not have to cut the frame at all for it to fit your 73 body.
Old Sep 17, 2009 | 06:44 AM
stpman's Avatar
stpman
If you don't change the frame rails on the 75 frame don't plan on mounting the rear bumpers with the stock brackets
Old Sep 17, 2009 | 06:57 AM
73BLWN's Avatar
73BLWN
I replaced my 73's with a 1969 frame. I don't recall having any issues. Others posted issues with the rear bumper supports. Odd since the changes would most likely be in the nose. I had no issues at all with nose.
Old Sep 17, 2009 | 08:45 AM
johns73's Avatar
johns73
I put a 77 frame under my 73 and the only change was to the last 18'' of the frame. No other mods were needed.
Old Sep 17, 2009 | 11:14 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'd use a 68-73 frame. The only mods for the non-73 frames (68-72) would be the need to relocate two or three holes in the frame horns for the bumper support (battering ram). No big deal.
Old Sep 17, 2009 | 11:41 PM
Buddy1980's Avatar
Buddy1980
Default 73 frame
the 75 frame will fit the 73, only mod is to alter rear bumper brackets. and the 75 frame is actually more heavy duty on the rear frame rails than the 73.
Old Sep 17, 2009 | 11:58 PM
63Nova's Avatar
63Nova
There is a guy here with a 73 he might be willing to let go of for 500.00
To 73 Frame Replacement
