Companion flange question
Old Sep 17, 2009 | 10:19 AM
Darrell's 68's Avatar
Darrell's 68
Default Companion flange question
Hi all. Was underneath my car greasing the u joints in the driveshaft and I noticed that my disc on the companion flange was loose. Is the disc supposed to be part of the flange as a slip fit and mine has just loosened with age? I did not take off the driveshaft to check if the flange nut is loose but it appears tight. I do not have any driveline vibrations and the rear is not leaking any fluid so I am inclined to believe that it is nothing serious. I do not have another flange laying around to compare. Any help or thoughts would be appreciated, thanks.
Old Sep 17, 2009 | 11:01 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
A picture would help.
Old Sep 17, 2009 | 03:24 PM
Darrell's 68
I will try later to post a pic of it but it is the flange on the front of the differential carrier that bolts onto the pinion gear. The disc does not look like it has a structural purpose. It only looks like it covers the pinion oil seal.
Old Sep 17, 2009 | 03:37 PM
bashcraft's Avatar
bashcraft
It's to protect the seal from flying debris.
To Companion flange question
