E85 fuel test on my C3
Old Nov 12, 2018 | 12:35 PM
  #101
davidbii's Avatar
davidbii
Thanks! I'm working the carb angle right now...I've got a high volume mechanical pump on it right now...do I need to go electric?
Old Nov 12, 2018 | 01:08 PM
  #102
v2racing's Avatar
v2racing
Originally Posted by L79racer
No it doesnt eat rubber or corrode aluminum.
This is what I have heard from racers and street guys running it. Most of the ethanol destroys everything and the world is coming to an end always comes from people who have never run it. That's why I advised the OP to go to E85 forums. I'm still considering running it in my Vette. It's everywhere around here.
Mike
Old Nov 13, 2018 | 07:07 AM
  #103
Kerz's Avatar
Kerz
Dang, what an interesting and diverse thread! I guess what surprises me most is the older cars that operated satisfactorily on E85. Usually, there is a significant need for more ethanol at the same operating conditions than gasoline. The optimal (stoichiometric) ratio/fuel ratio for E85 is about 9:1, whereas gasoline is about 14.7:1. Ethanol already contains oxygen molecules. Today's E85 vehicles have fuel injection systems with broadband O2 sensors and fuel sensors capable of making the wide-ranging calibration changes.
Many years ago, we worked with both Ford and GM on the effects of E85 on engine oil performance. Those vehicles had SS fuel tanks and lines, as well as other components designed for alcohol compatibility. If you decide to use E85 in a non-designed car, keep an eye of engine oil color and dipstick level. Only use oil that is formulated for alcohol fuels, i.e., racing oils.
Vic
