79 ac??
Old Sep 19, 2009 | 08:00 AM
jacobsed's Avatar
jacobsed
Default 79 ac??
I'm performing a body off restoration. I'm currently cleaning up the engine bay while the body is off the frame. The AC has not worked since 1992. Should I eventually make the existing system work or install an aftermarket? I do not care about originality but I do care to have reliable cold AC.
Old Sep 19, 2009 | 08:40 AM
Ganey's Avatar
Ganey
Just fix the A/C system. Mine works fine.
Old Sep 19, 2009 | 08:52 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
If you decide to use an aftermarket, I will buy your core and pay for shipping. Ive been looking for a 79' core fore a while now. If you would like to do that, just pm me and we'll work out the details.....Jeff...
Old Sep 19, 2009 | 08:58 AM
jacobsed's Avatar
jacobsed
If I were to make the existing system work, what would need to be done in terms of using r134?
Old Sep 19, 2009 | 09:00 AM
marshrat99's Avatar
marshrat99
When I installed my 355 a few years back, I had the same question. I'd driven my 79 a couple of years without the A/C working and thought that it was shot since it never worked. Anyways, taking a chance after my engine install, I simply reinstalled the pump, connected the wiring properly, charged and it has worked fine ever since.
A/C is a wonderful thing when it is too darn hot to ride with the T's off.
Old Sep 19, 2009 | 09:23 AM
Ganey's Avatar
Ganey
Some factory systems were converted from R-12 to R-134a by only 1 mech. change- reducing the orifice tube size!
Some A/C shops are changing the GM orifice tube to a Ford tube which has 2 O-Rings to seal better & is a little smaller.
Probably changing the GM white orifice tube .072 to the Ford red .062 would be best orifice tube.
There is also a Variable Orifice Valve that can be used instead of the orifice tube. I am still running R-12 & have been looking into R134.
Old Sep 19, 2009 | 01:23 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
I can't believe it but I found one today in a '79 parts car that a local Vette restorer had laying around....$40 !!! and it still has the original sticker on it....I'm happy !....
Old Sep 19, 2009 | 04:10 PM
08vycpe's Avatar
08vycpe
I agree with Ganey. You can fix your existing A/C but you might need some special tools (like a vacuum pump). Some tools can be rented free from Autozone.
Here is a link to a "how to" article for converting from R12 to R134a in a 77-82 Vette. I rebuilt my A/C in my '79 recently. Be sure to replace the accumulator/dryer, oriface tube, compressor, all o-rings (to the green R134a compliant ones), pressure flush, replace oil with ester oil, evacuate with vacuum pump for 1 hour and fill. The conversion kits come with the correct new fittings.
http://www.corvettemagazine.com/comp...iendly-ac.html
To 79 ac??
