Stumbling at idle...
Old Sep 20, 2009 | 09:10 AM
Apocolips's Avatar
Apocolips
Default Stumbling at idle...
While idling the engine is mostly smooth. Every once in a while I hear it stumble a little and then back to smooth. So, I changed the plugs, points/condenser, rotor, new fuel filter, set the dwell and timing. I even threw an oil change to boot. Started it up and it still stumbles. It’s a 350/300 automatic , idle set at 650 in a 1970. Any ideas?
Old Sep 20, 2009 | 09:27 AM
1conic's Avatar
1conic
has it got aircon?
Old Sep 20, 2009 | 09:34 AM
Apocolips's Avatar
Apocolips
No, the A/C has been removed!
Old Sep 20, 2009 | 09:37 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
I had intermittent "stumble" as you call it after I took my '79 out of mothballs after 15 years and it turned out to be a loose red wire to one of the alligator plugs near the passenger side firewall between the distributor cover and the alarm plunger.It was a hot power wire....With the car running , move them around and see if you can produce the stumble.....It's hopefully maybe that simple.
Old Sep 20, 2009 | 09:41 AM
Apocolips's Avatar
Apocolips
Originally Posted by jeff79'
I had intermittent "stumble" as you call it after I took my '79 out of mothballs after 15 years and it turned out to be a loose red wire to one of the alligator plugs near the passenger side firewall between the distributor cover and the alarm plunger.It was a hot power wire....With the car running , move them around and see if you can produce the stumble.....It hopefully maybe that simple.
I'll give it a try..
Old Sep 24, 2009 | 01:18 PM
Matt Gruber's Avatar
Matt Gruber
afraid to touch those mixture screws?
To Stumbling at idle...
