1971 bb rear composite spring rate?
Old Sep 20, 2009 | 11:19 AM
airtime's Avatar
airtime
Default 1971 bb rear composite spring rate?
i have an original 71 bb auto. car has a composite rear spring. no manufacturing name but has a serial number and some other numbers. trying to decide what spring rate i have so i can order my shocks.
serial number is 0203139
other numbers in seperate blocks are 602 101 103 105
thanks for the help. also i know people are running 550 springs up front, any particular brand? are they all the same height? not looking for a skate board here just a solid handling car that my wife can drive every day. by the way, looking at the bilstien hd shocks
Old Sep 20, 2009 | 12:20 PM
airtime's Avatar
airtime
ttt
Old Sep 21, 2009 | 08:16 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Check the spacer that sits upright between the two steel plates. 634-127 = 315lb, 634-128 = 340lb, 634-129 = 355lb
Old Sep 21, 2009 | 11:40 AM
airtime's Avatar
airtime
i'll look and take some pics today. don't remeber seeing anything on that but i'll recheck. thanks
Old Sep 21, 2009 | 12:24 PM
airtime's Avatar
airtime
muskegon brakes, i was told this was a trw spring. i know you are a dealer for them. does any of those number mean anything to you? the spring would have been purchased in 94 or 95. thanks.
Old Sep 21, 2009 | 04:14 PM
CFD E59's Avatar
CFD E59
Hi, you are correct this is a TRW spring. On the spring where the numbers were 602 101 103 105 if you look at this closely you will see that under the the 100 #'s one of them will be punched out or stamped, either a circle or a diamond. That is how you tell the spring rate.
101 103 105
315 340 355 rate
Here is a link. content.mamotorworks.com/pdf/602836.pdf
hope this helps.
Old Sep 21, 2009 | 05:51 PM
airtime's Avatar
airtime
thank you cfd. i'll look tonight.
Old Sep 21, 2009 | 10:18 PM
airtime's Avatar
airtime
103 it is. 340 lbs. is this ok for a stock big block with factory rear sway bar? i just ordered the sport bilstien shocks and 550 lb front springs? i was kinda worried about ordering the shocks without knowing the rear spring rate.
Old Sep 22, 2009 | 08:58 AM
CFD E59's Avatar
CFD E59
Glad to help.. I too have the 103= 340 rate spring and went with Koni's shocks, and on the front I got the 460 springs thought the 550 would be too stiff for Chicago streets.
Old Sep 22, 2009 | 10:29 AM
airtime's Avatar
airtime
250 lbs would be too bad for those streets. lol
thanks again for the help. i hope i can just pop off the lower ball joints and slip the new front springs in using my old trusty floor jack.
To 1971 bb rear composite spring rate?
