What is this part called?
Old Sep 20, 2009 | 11:59 AM
vetteguy112233's Avatar
vetteguy112233
Default What is this part called?
Just replaced all headlight vacuum lines with kit from Ecklers.
In the nose of the car, there are 2 vacuum distribution blocks that help the headlights come up and down, there are 3 hoses connected to each. What is this called, I think mine are bad and can't find replacements.
I can blow in each hose with the red line and each headlight comes up. I can suck the air out and each goes down, but when I go throuth that distribution block, I can hear air leaking from the bottom of this block, same with the other one.
Is this common, is there a cheap fix or do I just replace them?
Old Sep 20, 2009 | 12:04 PM
vetteguy112233
Right after posting I found it, looks like they are called the Headlight & Wiper Door Vacuum Actuator Relay.
Is this a common problem, is there a quick/cheap fix for air leaking out near the bottom somewhere?
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
www.corvette-101.com
This webpage has a help section that should help you with the troubleshooting of vacuum problems. From your description, I think you are talking about the vacuum control relays.
Old Sep 20, 2009 | 12:20 PM
vetteguy112233
I forgot all about that website, thanks for the reminder!
It has a section on how to test the actuator and rebuild it if necessary.
THANKS!!!
Old Sep 20, 2009 | 03:43 PM
boatdoc's Avatar
boatdoc
There are some on Ebay now for $38.00 each. I didn't think it was worth my time to try and rebuild them. Now, the actuators were a different story, they're a snap to rebuild with the new seals and boots.
Old Sep 20, 2009 | 05:56 PM
Ganey's Avatar
Ganey
The relays can be restored w/ some black RTV.
http://forums.corvetteforum.com/c3-g...of-vacuum.html
Old Sep 20, 2009 | 06:09 PM
69small block's Avatar
69small block
Default relay
where excatly do you put rtv do rebuild has 2 versions of these one is us made for 115.00 or off shore one for about 60.00
Old Sep 20, 2009 | 06:24 PM
Ganey's Avatar
Ganey
Restore w/ black RTV to the seals.
Un-crimp, remove plunger, clean rubber with alcohol, apply some Black RTV to seals, let dry some. Apply a little Vaseline to tube, re-install plunger, spring and cap, and re-crimp.
See the topic link I posted. 71 Green 454 posted pics. when he did it.
To What is this part called?
