mini starter
Old Sep 20, 2009 | 01:49 PM
glo's Avatar
glo
Default mini starter
Trying to get starter line up.I can get starter line up and paper clip space between teeth with the front bolt tight. When I tighten back bolt it pulls starter into flywheel. Tried shims from 1-5 same issue .
The bolts came with starter.
Old Sep 20, 2009 | 03:44 PM
WESCH's Avatar
WESCH
Hi
Check the surge function, many threads on this already.
Use more shims and it will be OK.
Had the same issue. The supplied shims where not enough.
Watch the grip length of the bolt. Using 2 or 3 more shims should be OK for them.
Rgds. Günther
Old Sep 20, 2009 | 03:55 PM
WESCH's Avatar
WESCH
Hi again.
Pulled one thread for you: http://forums.corvetteforum.com/c3-t...r-binding.html
Rgds. Günther
Old Sep 20, 2009 | 10:01 PM
glo's Avatar
glo
Thanks that will help
To mini starter
