brake lights
Old Sep 20, 2009 | 09:41 PM
brngrhd's Avatar
brngrhd
Default brake lights
well i got my car running with the 468 th400 nine inch and 4 link car runs and drives great motor is strong car hooks well..... but i was told that i don't have any brake lights the turns work but no brake..... any ideas..... had then when it got put away for the rebuild..... have not done any testing as of yet
Old Sep 20, 2009 | 09:58 PM
...Roger...'s Avatar
...Roger...
stop light fuse or brake switch....what year ?
Old Sep 20, 2009 | 10:11 PM
brngrhd's Avatar
brngrhd
69.... i really need to get a service manual to tell me what is what LOL
Old Sep 20, 2009 | 10:29 PM
...Roger...
If your going to be working on wiring get one of these you won't be sorry.
http://www.docrebuild.com/oosoez/8969101.html
Old Oct 1, 2009 | 03:00 AM
bntrainmaster's Avatar
bntrainmaster
1st Gear
Roger, do you have a diagram for 68? My brake lights will not work either. i have checked the brake light switch, 12+volts coming out. All fuses are good, and all grounds at the rear are tight. i assume its the turn signal switch??? because i have jumped the (white) wire coming from the brake light switch to the "green brake light" wire on the half moon connector that goes back to the rear of the car. it works but if i have my right blinker on and press the brake at the same time the blinker stops blinking.. i have tried to jump it to the yellow wire, which is the left blinker and it does the same. (stops blinking) i figured if i was in traffic i would rather have the left blinker working, rather than the right blinker... or at least until i can figure out what it is...
any advice pls help.
Old Oct 1, 2009 | 08:48 AM
...Roger...
Once you jumper the white to the green or yellow and step on the brake you have bypassed the turn signal switch-no blinky. Sound like you have a problem in the turn switch. Some have been running a separate single brake light wire to the rear doing away with the backup light or adding one.
To brake lights
