radio help
Old Sep 21, 2009 | 01:00 PM
base1957's Avatar
base1957
Default radio help
1968 vert
Bought the KHE3006876F from wilcox. zanyone used this and if so can you tell me the set up you utilized. i am looking for speakers to fit the front kick area, an amp , rear speakers and possibly a cd.
any combinations you have used to give me ideas are appreciated
I want good sound and don't mind spending a few bucks to get it
thanks
Old Sep 21, 2009 | 08:31 PM
base1957's Avatar
base1957
Default stereo help 68 vert
ttt
Old Sep 22, 2009 | 11:13 AM
base1957's Avatar
base1957
ttt
Old Sep 22, 2009 | 11:17 AM
Paul L's Avatar
Paul L
Originally Posted by base1957
1968 vert
thanks
See my earlier comments and pics on this subject.
http://forums.corvetteforum.com/c3-t...ent-radio.html
Old Sep 22, 2009 | 12:54 PM
base1957's Avatar
base1957
Paul
what bass do you have in the rear.
I have no dash speakers so will probably put two more in the rear with the sub
thanks
Old Sep 22, 2009 | 12:56 PM
base1957's Avatar
base1957
paul
will those POLK 651 fit into the existing kick panel speaker area
Old Sep 22, 2009 | 01:16 PM
Ganey's Avatar
Ganey
Some 5.25 can be fitted to kick panel location behind the panels.
A mounting plate must be used to separate the front from back sound waves to prevent cancellation for better bass. The speaker should be solidly mounted so that the movement of the speaker cone is translated into sound rather than any movement of the speaker. If the tweeters are separate or adjustable, tilt up & back towards the center.
Amp. can go in center back storage compartment.
Kenwood eXcelon mask CD
Kenwood eXcelon 5.25 Components in kick panels.
http://forums.corvetteforum.com/showthread.php?t=634468
Old Sep 22, 2009 | 01:40 PM
Paul L's Avatar
Paul L
paul
Yes.
Old Sep 22, 2009 | 01:46 PM
Paul L's Avatar
Paul L
Paul
thanks
The bass in the rear is the Blaupunkt 8" subwoofer. I chose it because it has an integrated amp: no need for a separate amplifier.
It draws power directly from the battery.
To radio help
