Need to replace Temp Gauge - 1977 Corvette
Old Sep 21, 2009 | 08:09 PM
MosportGreen66's Avatar
MosportGreen66
Default Need to replace Temp Gauge - 1977 Corvette
Hi Guys,
Can you tell me what’s involved in replacing the temperature gauge on a 77 Corvette. The one in the car is always pinned way right.
Thanks,
Dave
Old Sep 21, 2009 | 09:10 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it may not be the gauge....it may be the sending unit.....the sending unit is in the water jacket on the passenger side of the engine under the exhaust manifold see if the wire is hooked up to and it then disconnect it and ground it and see if the gauge moves.....also could be the wiring circuit behind the gauges tha is very flimsy...start with the sending unit
Old Sep 21, 2009 | 10:41 PM
Glassbowtie77's Avatar
Glassbowtie77
excellent advise, however the sending unit is located on the driver's side on a '77 with the original motor.
Old Sep 21, 2009 | 11:39 PM
MosportGreen66
Thanks for the advise. Should it turn out to be the gauge, how would I swap it?
Thanks,
Dave
Old Sep 22, 2009 | 12:11 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If the gauge is pegged to 3 O'clock the ohms wire is grounded out! Your gauge is probably fine and you have a wire issue.
Check the wire from the sending unit to the dash.
Check the terminals on the back of the center console at the connector.
Post again. . . We'll be watching.
Willcox
Old Sep 22, 2009 | 12:29 AM
...Roger...'s Avatar
...Roger...
Thanks,
Dave
You have to pull the entire center cluster.
Old Sep 22, 2009 | 09:23 AM
bobs77vet's Avatar
bobs77vet
yup you are right i guess dont know why i said that....its not what i saw in my mind....
Old Sep 22, 2009 | 11:14 AM
MosportGreen66
Hi Guys,
Thanks for the info. It will be a while until I get around to looking at the car. Just wanted to get my facts straight, before I tackle the project. Always learning.
Thanks!
-Dave
To Need to replace Temp Gauge - 1977 Corvette
